Fiat 2.8 Ignition Key Code Problem
Discussion in 'Tech/Mech General' started by Autotrail700, Jul 27, 2009.
  1. Autotrail700
    Autotrail700 Deleted User
    Hi all, new to this forum but hardly new to motorhomes after 28 years with them! I was recommended to the forum after meeting member 656 in Calais last week. He recommended you knowledgeable fellows for some trouble I am having with my fiat ignition. It appears to be an increasing intermitant fault, sometime upon trying to start the MH the key code recogonition light remains on and locks the desiel pum not allowing the MH to start (It will still turn over). Repeated attemps with the other keys swapping between the sets and keep trying usually gets it started but as describe the problem is now becoming very frequent. Has anyone esle had this issue and kknow of a possible fault or even rectification? I have heard with many computyer faults you can often resest a certain part of it yourself often solving the issue?
    Any input would be gratefully recieved.
    Kind regards,
    Andrew
  2. gypsylady
    gypsylady Read Only Funster
    Jun 24, 2008
    251
    104
    Durham
    Posted via Mobile Device
  3. gypsylady
    Jun 24, 2008
    251
    104
    Durham
    Hi I am having the same trouble and do not know what to do .If you find out what this is would you let me know like wise I will with you.
  4. bauldy
    bauldy Read Only Funster
    May 13, 2009
    36
    bedworth
    You could try a lock-smiths for some advice or a fiat garage.
  5. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    hi Andrew
    Nice talking to you and your Mrs at Calais on Saturday. Someone will be along with an answer I am sure.
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    This is a very common problem and seems to be associated with the fuel pump/ immobiliser control box Fiat as usual are in denial of this fault, there is an easy fix, as it concerns the vehicle security I am reluctant to post openly about it, you can PM me for more info if you are handy with minor electrics I will try and steer you in the right direction
    It is reported that Fiat will spend many hundreds of your pounds trying to fix it properly:Eek!:
    • Like Like x 1
  7. 656
    Jul 30, 2007
    1,150
    291
    The universe
    Andrew
    Geo is the dogs when it comes to these sort of things. I hope he can sort you out, maybe you will get to meet him - and others - at a meet.
  8. Autotrail700
    Thanks to all for their input, Geo PM sent, I begrudge paying fiat a fortune to fix a problem I can sort myself (with a bit of help from you knowledgeable folk!) :BigGrin:
  9. Talisio
    Talisio Read Only Funster
    May 13, 2014
    Suffolk
    Geo, just found this thread after days of searching. Having this problem with a fiat Doblo, I don't have permission to private message you yet, could you please contact me with a fix I am desperate! My email is mstmears@gmail.com.
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,936
    17,599
    YO11 2BD
    pay your £10 subscription and you can pm Geo to your hearts content....until you are a fully paid member you cant pm.
    Geo's advice will save you many, many times the £10 subscription fee so you're already on a winner.
    • Like Like x 2
  11. wanderer
    wanderer Funster
    Apr 14, 2008
    441
    396
    huntingdon
    When i had a similar problem i reprogrammed my keys into the alarm system with instruction from Sigma
  12. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,533
    9,952
    if its the pre 2006 model, its probably the receiver ring around the ignition keyhole that detects the chip in the key. they sometimes get loose and move or start failing. another fairly simple cure is bypass the immobiliser. any decent auto electrician will be able to do it for you
