Fiamma Zip Safari Room Issues
Discussion in 'Motorhome Chat' started by Wollow007, Jun 14, 2012.
  1. Wollow007
    Wollow007 Read Only Funster
    Dec 17, 2011
    36
    Reading
    Hi guy's,
    Has anyone ever had the issue with the door clashing with the Zip awning rafter when installing a Safari room, whatever I seem to do it still clashes. The Motorhome is a a 2003 Swit Sundance 630G.
    It appears that it is a known issue, and to be honest I have looked into all the solutions and none seem to work, I can't move the awning up, rafters are fixed and can only move a couple of inches, I have adjusted the dampers etc but still need to find around 6 inches to move the rafter away from the door enough. I can install the safari room but need to have the leg on the awning nearest the door extended spot far and the safari room skirt pulls away from the Motorhome side near the door, is pants.
    So my options, sell the Fiamma Safari room, which is nice quality but only really gives you a single room or buy one of these bad boys
    http://www.khyam.co.uk/detail.asp?p=759&product=Motordome%20Sleeper%20Plus
    What do you guy's think, bit miffed about needing to spend more dosh on an awning, but really use the extra space, do a lot of mountain biking in a crowd so extra sleep space will be used. :Eeek:
  2. Emmenay
    Emmenay Read Only Funster
    Dec 11, 2011
    364
    274
    Anywhere
    Had the exact same issue recently when I set up for the first time.
    I had to slide the support bar above the door along about 5-6 inches as well as the other end of the beam the same amount. Be careful though, if you move it too far you will not be able to close the awning.
    You only need to slide it far enough that the door just passes underneath the beam. It may take a few times to get it right but it will be worth it in the end :thumb:
  3. Wollow007
    Dec 17, 2011
    36
    Reading
    Will give it a go, had a look but thought i would need to move the rails to far, worth a go though :thumb:
  4. Philb
    Philb Read Only Funster
    Aug 3, 2011
    37
    6
    Carmarthen Wales
    I have the same issue with the awning. I too bought a khymer and it assembles very easily. The only drawback is the tunnel to the motorhome sags a little and care is needed when opening the hab door.
    It would be a better design if all the sides of the tent opened as well.
    One side door and window,
    Main side away from m/h the whole side opens up
    One side window only..
  5. welshbois
    welshbois Read Only Funster
    May 8, 2010
    312
    174
    South Wales
    Ours is fine and no issues. We love it.:BigGrin: Hope u sort it.
Similar Threads
  1. tw1nklestar
    25
    870
  2. Jim
    4
    360
