Fiamma roof vent, is it me? (1 Viewer)
Billy23
1,610
2,984
On a planet...far, ....far away.
On and off 1995
I broke the top vent on the MH, so I phoned John Cross and ordered a new on, great service and 10% Motorhomefun discount, so far so good.
Took it out of the box today, thought I would start to fix it, they tell you (Fiamma) to fix it to the roof using 20 4.2x30mm screws, and the underneath part with 4 self tapping 3.5x15mm screws.
So were are they, I mean if they can tell you the screws that you need, why are they not in the box! Oh! we don't supply the screws!!!!:mad:
Is it me? I expect to find the bloomin screws in the box, I mean for goodness sake supplying 24 screws is not that expensive instead of £40 why don't they throw the screws in, or even charge £40.50. You get all ready to fix it, them have to go out and get the screws.
I am going to have a beer now.......or even 2 :)
Badknee
7,407
412,714
notloB
Vantage Neo
Living the dream.
I'm with you on this rant. I understand " batteries not included" as they may be flat by the time the item is sold but screws, na, should have been there.
Badknee
7,407
412,714
notloB
Vantage Neo
Living the dream.
Oh no David, unfollow this post. You'll never be the same again lol.
tambo
874
639
Dunfermline fife scotland
a class
MH Since 2008, ex tugger and vw campers since 1992
20 holes in roof wouldn't be me
I fitted a mini heki the other day only hole in roof is the square one the vent screws together top and bottom
And a screws plus extras in box
Got the other one to fit on Wednesday
Omnistor vents I removed are the same no screw holes in roof
You just need one of those 20 to leak and you have problems
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
this may not be well timed if you have now had both your beers, but if were only replacing the thing why could you not reuse the old screws?
or have I missed a key fact (again) :D
Billy23
Billy23
1,610
2,984
On and off 1995
this not be well timed if you have now had both your beers, but if were only replacing the thing why could you not reuse the old screws?
Thought, BEFORE I take the old one off, have ALL the equipment handy as the old screws might be stuffed, this is a first for me as I normally start a job, going well....until halfway through....then, Oh! Poo, I haven't got that bit, shops are shut, then, my dearly beloved says.....WHY didn't you make sure BEFORE you started! And you know what happens then, don't you my friends!!:)
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
have a few more , fix the bloody thing with 6 inch nails, use the spikes as an aerial, sorted!
Till you sober up!
Sep 21, 2013
226
241
Isle of Wight
coachbuilt
since Apr 2013
I agree with you mate if they know what you need to fix it put the bl**dy stuff in the box. After all the one you took out might not match the one that's being refitted in the screw positions. After all we fella don't like screwing in the same position or place.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I fitted a couple of Fiamma vents on the In-Laws motorhome.
I thought it best to use stainless screws for the job.
We have the same vents on our Chausson, no leaks so far!
Jan 8, 2014
1,038
2,519
Emsworth
Bailey 740
always best to supply your own screws to allow you to buy quality. I never use screws supplied with anything as they are usually made of toffee and the heads just round off. The same goes for raw plugs
Nov 21, 2011
64
31
ESSEX
Elddis Autoquest 400
7 years
If I buy anything for our van new I resist the temptation to buy anything that has the Fiamma logo.Its generally over priced crap!
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Ummm.. why not just replace the bit that is broken and leave the original fitting in place ? ( or is it the surround that is broken ? .. In which case ... I have to ask ... HOW !!!! :D )
Billy23
Billy23
1,610
2,984
On and off 1995
Weeeeell, I had my MH parked under my sun shelter, unknown to me, my darling wife had raised the vent....like full! I then drove forward and the "Lid" hit the roof support of the sun shelter and twisted the bar that is used to raise and lower the "lid" so much so that it will not close. I am going to get onto the roof and have a proper look at it in the next few days as the weather is now cooling down and it wont be to hot (near Seville Spain). The problem was that I thought it better to buy a new one whilst we were in the UK (soon to be England and Wales :) ) as it would be difficult/expensive and time consuming to get it once back at my Spanish winter house.
It may be possible for me to repair, but as I once tried to be a girl guide, I thought that I would be prepared.
I will also tell you Mr Jaws, that is not the only daft thing that we have ever done.;)(y)
Minxy
32,649
66,541
E Yorks
Carthago Compactline
When I replaced the roof vent on a previous motorhome I didn't use any screws on the outside at all - just the requisite 'ribbon' sealant which did the job and the screws inside to attach the ceiling cover to the outer ... job done.
Just a word of warning ... the old sealant will be an absolute b*gger to get off so be prepared to spend a lot of time up there with a plastic scraper (old credit card with one edge sharpened) getting it off ... I speak from experience as at the time I decided to replace TWO and wish I'd only done one! :rolleyes:
Billy23
Billy23
1,610
2,984
On and off 1995
Thanks for the info, I will start it on Monday, tell me, did you roof vent have holes for the screws? If they did, you must have thought, well I won't bother, which is something I have been thinking because as you say, the sealant sticks like s*ht to a blanket.:)
tambo
874
639
a class
Turpentine and a sponge scourer works well removing the old sealant and a Stanley blade ....
tambo
874
639
a class
They probably fitted similar to the one I just removed or the dometic seitz mini heki I just fitted ....no screws to go through roof the outside bit gets stuck on with mastic and the inner bit screws to the outer part from inside ....there's only one hole in the roof that way instead of 21
If you've 20 existing holes in your roof fair enough fit the fiamma but if you haven't then I'd seriously reconsider fitting one now
Billy23
Billy23
1,610
2,984
On and off 1995
After reading your post, I thought I would inspect the new vent, sure enough the inside screws to the out side with four screws. Looks like I will forget screwing the top bit to the roof, unless the holes are already there, and just stick it with mastic and screw up from inside.
It just has to be worth £10 per year to get such a lot of advice. (y)
If I pay another £5 will somebody passing junction 53 Seville Huelva motorway, drop in and help, you can even park up overnight. :):whistle:
tambo
874
639
a class
To be honest I've not seen any that screws to the roof but you never know :)
At least your im a mostly dry climate hear in Scotland you need it to be seriously water tight lol
