Fiamma Roll Tank 40 litre Waste Tank
Discussion in 'McLouis' started by playbyte, May 12, 2008.
  1. playbyte
    playbyte xMember
    May 4, 2008
    36
    Kirton-in-Lindsey
    Does anyone know where i can get the "Sanitary-Flex drain tube" refered to, or any other tube with the right fixing to allow me to dispose of waste water properly?
    I have the manufacturers waste water tanks fitted to the motorhome but no pipes to bring it out to any kind of portable waste tank.
    At the moment we either have to position over a grey water dump grate or position a washing up bowl under the outlet to catch the water when we pull the release handle.
    As one of the outlets is directly above the exhaust pipe the grey water spalshes all over the place and more goes out side the bowl rather than in it.
    Playbyte
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    East Sussex 01-580-881288
    Hi, yes we can supply Sanitary Flex Kits
    products matching 'sanitary'
    Stock Code Description
    8004815196082 Sanitary Flex Kit
    Regards
  3. playbyte
    playbyte xMember
    May 4, 2008
    36
    Kirton-in-Lindsey
    Thank you we will be getting in touch, is there a particular person we need to speak with?
    Roger
  4. N Luyetund
    N Luyetund Deleted User
    Hi Playbyte
    Our grey outlet had a female threaded fitting, we bought a plastic fitting (from Brownhills:thumb:) which allows a hose to be connected...
    ...had trouble sourcing a hose but a little lateral thinking and we now have a washing machine hose (the one with an open conical fitting that pushes on) bought from the local market washing machine accessories stall ...cost £3.50...
  5. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    Not really, most of the shop staff know their bits and pieces, its on our website if you want to order without phoning.
    We will be a bit shorthanded in the shop over the weekend due to staff going to Newbury.
    Regards
    Peter
