Fiamma / Omnistor tie down strap (1 Viewer)
golly
2,005
69,615
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Our van is the first we have had with an awning (Omnistor), I have a tie down strap but have seen a couple of ways to use it. Some seem to put it over the extending arms but under the canvas, others put it over the canvas. Is there a preferred way to use it or is one as good as the other.
cheers John
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
If it is the long strap type, then under the awning and over the arms.
If it is the two strap type, then slot the end into the front of the awning edge
Peter
golly
golly
2,005
69,615
HYMERCAR PVC
since August 2009
Peter
Thanks Peter, its the long strap, I thought that would be best as I think it would wear the canvas if over the top.
John
TheBig1
17,630
43,262
the best way to attach a long strap is under the canopy, but be aware that in strongish winds this puts a lot of pressure on the leg pivots. for about £16 you could buy the straps designed for canopy awnings, that allow you to disconnect easily and put the awning away.
have seen a few canopy awnings like fiamma and omnistor flipped onto the roof of motorhomes in what can only be described as moderate winds. the worst weather for damaging them is gusts of wind. you can try tying it down all you like but a 4m x 2.5m sail takes a whole lot of holding down
Aug 18, 2011
12,139
18,004
derbys
AUTOSLEEPER SYMBOL
Guy ropes help as well. BUSBY:Smile:
43,323
49,438
as said the knuckle joints at the top of the legs take a real beating when the awning is strapped down too tight....I know 'cos i broke one..
if yours has plastic knuckle joints consider replacing them with aluminium ones.
