Fiamma F45 question
Discussion in 'Motorhome Accessories' started by Steve N Tracy, Sep 27, 2015.
  1. Steve N Tracy
    Steve N Tracy Funster
    Jun 1, 2015
    199
    118
    Southampton
    After many years tugging a caravan, we picked up our first motorhome on Wednesday, and I have a question is it normal for the Fiamma awning to rattle all the time you are driving? its only a 3,5 mtr version, I have fitted foam pads to try and stop the arms rattling inside the casing when shut, the red indicators say the awning is shut correctly, any thing else I can try?
    Regards
    Steve
  2. Charlie - Minton
    Charlie - Minton Funster
    Dec 4, 2014
    603
    1,563
    Cheshire
    Ours is fine with no rattles.
    That said its only a year old & covered about 2000 miles.
  3. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,679
    3,258
    Cumbria
    Ours doesn't rattle but it creaks and groans a bit when you wind it out.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    Are you locking the legs in the same way as when in use using the two thumb wheels.
    Place the leg in the front case then Lock the leg slightly longer with the knuckle joint sticking out then press in using the knuckle joint at the end.
    The tension on the legs will then stop the rattle.
    I could have sworn the red flag indicates not fully closed and changes to green when it is locked....could be wrong.
    • Like Like x 1
  5. Manic
    Manic Funster
    Nov 4, 2011
    984
    1,112
    Uk
    On the F45S they are different to the Ti version and don't have anything to tension legs against. I just do leg nut up and then it clips into plastic clips in front rail.
  6. Steve N Tracy
    Jun 1, 2015
    199
    118
    Southampton
    Hi thanks for the info this seems to work, its a 45S model so only a red indicator that slides in when locked.
    Steve
