fiamma awning wont wind in (1 Viewer)
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
does any one know where i can get the winding mechanism on the end of the awning from?
when i put the bar on and try to wind in the awning it just spins around:Sad:
ive took it off and its all threaded meaning i had to wind the canopy in with a spanner and strap it up to get home, ive been looking around on the net and can only find the electric ones and they are a bit on the expensive side.
T
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
cheers ive been looking but cant seem to find it, i think its called a winch slot, i will call them in the morning if i have no look finding it
T
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
does the ring pull down onto the dog clutch or wont it pull down.?
i dont understand what you mean? i put my winding pole into the loop at the end of the awning to wind it back in and it just spins like its rounded off inside and wont bring the canopy back in
43,321
49,408
when you place the hook end of the pole in the ring on the awning gearbox you need to pull it down and hold it down as you turn the pole :thumb:
unless the design has changed
T
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
cheers pappajohn,on mine all that as to be done is just turn it.
43,321
49,408
Ok...design must have changed since mine was installed :thumb:
if your's wound out, it should wind in.....cant see the gears all striping while its stationary and if it had you would still feel some resistance as the remains of the teeth slipped over each other.
maybe worth a try pulling down......could have been stick down from new and just released itself.
clutching at straws maybe :Blush:
T
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
mine is the fiamma zip 450 deluxe does any one know which is the right 1?
T
tommytli
May 26, 2009
434
26
lancashire
coach built
since july 07
all the gearing has rounded off:Sad: and the worst thing is its just out af warrenty:cry:
