Fiamma Awning HELP....
Discussion in 'Motorhome Chat' started by missbusybusy, Jan 22, 2012.
  1. missbusybusy
    missbusybusy Read Only Funster
    Nov 27, 2011
    93
    36
    Northampton
    we have a Fiamma F45 awning fixed to the side of the van and have just purchased a ZIP safari room, it comes complete with a RAPID SET system, before we take everything out of the bags and get even more confused no instructions that make sense !!
    DO we NEED anything else or does this rapid set system fit the safari room to the wind out awning :Sad:
    Thank you
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,255
    17,926
    YO11 2BD
    looking at the picture i would say you have all you need, but there may, can really tell off the pic, be a pad/bracket to fit to the awning housing which the pole will fit into..
    [​IMG]
  3. missbusybusy
    Nov 27, 2011
    93
    36
    Northampton
    awning
    Thanks, yes I see what you mean,
    there are multiple bags of bits with only picture instructions inside but I am trying to stop Hubby opening them all (as you know what will happen)
    I presume then the sides will fix somehow to the awning ?
    regards
    Carol
  4. pappajohn
    Aug 26, 2007
    30,255
    17,926
    YO11 2BD
    never seen one, or if i have i havent taken notice, in action so cant advise :Sad:
  5. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
  6. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,676
    7,472
    South Yorkshire
    The first thing you have to determine is whether or not you have a Zip awning ie the awning has zips running along the end edges. If you have, the safari room will zip directly onto the awning. If you have'nt got a Zip awning then I think you might have a problem.
    • Like it Like it x 1
  7. missbusybusy
    Nov 27, 2011
    93
    36
    Northampton
    Thanks, Great Video and only 4mins 30 to put up :BigGrin:
    The awning has no zips on the outer edges, umm so what is the rapid set system used for ?
    and so the ZIP safari room actualy is only designed for a ZIP awning ?:cry:
    is there a kit that can be used to match the two together ?
  8. stcyr
    stcyr Funster
    Apr 11, 2011
    1,684
    1,119
    Normandie
    We have a Zip awning on our current MH and it has zips along the edges, as mentioned above, to attach the Zip safari-room. Our previous MH had one like yours, F45, and it and the safari-room for that model did not have zips. :thumb:
  9. pappajohn
    Aug 26, 2007
    30,255
    17,926
    YO11 2BD
    it appears the rapid set system is nothing more than an extra rafter pole and combined leg.
    it will be to give more support for the heavy awning fabric and actually has nothing to do, other than that, with the awning room.
    could be used on its own if you wanted.
  10. missbusybusy
    Nov 27, 2011
    93
    36
    Northampton
    :cry::cry:
    thats going to make him really happy :RollEyes:
  11. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    East Sussex 01-580-881288
  12. stcyr
    stcyr Funster
    Apr 11, 2011
    1,684
    1,119
    Normandie
    Just a thought: is there a sort of beading alongside the zips on the side-panels? I seem to remember in the Fiamma blurb there was a mention of the Zip privacy-room sides having 'the addition' of zips. So maybe they can be attached to the rapidset poles as an option? Worth a look before panicking!! :Eek!:
    PS: I'm sure Peter (Johns Cross) will be able to throw some light on the question!
  13. missbusybusy
    Nov 27, 2011
    93
    36
    Northampton
    after looking at the videos and documents does anyone know if the
    clip system will work with the ZIP privacy room on a standard awning ?
    thanks
  14. SilverF1
    SilverF1 Funster
    Nov 14, 2010
    110
    68
    Worcestershire
    I have a clip system Fiamma privacy room on a standard F45i rollout awning. The room sides slide into the grooves on the clips attached to the awning, the front slides into the groove of the awning front bar, the sides and front of the room zip together.
    The clips fitted to the awning need a locating mount screwed to the inside of the awning holder on the van. These should be in a bag associated with the clip system.
    HTH
  15. missbusybusy
    Nov 27, 2011
    93
    36
    Northampton
    ok, thank you I think I am getting the hang of them now (SLOW I KNOW :RollEyes:) to which are compatible,
    BUT
    clip system will work with the ZIP privacy room on a standard non zipped awning ?
  16. missbusybusy
    Nov 27, 2011
    93
    36
    Northampton
    well it looks like the privacy room is now for sale :Doh:
    Brand new Fiamma ZIP 4.5M Large,
    or swap for standard non zip model 4.5M Medium or large :RollEyes:
  17. con-tiki
    con-tiki
    Oct 18, 2009
    475
    189
    Leeds, West Yorkshire
    Why not replace the canopy for a zip....The price for a new zip privacy room is more than the price for a new zip canopy..I personally prefer the zip system as it is quicker to put up...:BigGrin:
    Shirl
