Fiamma awning and wind speed (2 Viewers)
Jul 10, 2014
179
57
Cheltenham
Elddis Encore 255
3 years
I know the answer is use your common sense but at what sort of wind speed should you roll them in? We have 4.5m and always use straps to anchor it.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
From what I saw happen to a friends van last year it is the sudden gust that comes from seemable nowhere that does the damage. Unless you are sat under it put the storm straps on almost every time
Feb 24, 2013
13,073
101,433
Bolsover, Derbyshire
Hymer S800
not long enough
and beware the storm straps, after reading such threads on here we bought some ratchet straps attached to some of the fittings that slide into the awning front.
We have now permanently bent the front rail on our awning, so badly it will not go away properly o_O
I think I will be treating mine as a sun shade for nice days only when we get ours swapped
Mikey RV
4,900
24,212
Devon
Burstner Elegance I821G
Since 1977
I never put mine out in anything above a gentle breeze. Have seen too many damaged including one going right back over the top of the motorhome. It's the inconvenience of it all and cost for putting damage right and new awning. Ours is 6metres long so catches the wind easily. It's a shade if the Suns hot.
Lenny HB
53,398
149,816
On the coast in West Sussex
Hymer B678 DL
Got so fed up with having to put it away after 10min didn't bother with one on this van not really missed it apart from a few days in Germany a couple of weeks ago when it was 34 every day. Haven't bother with one on the new van we have just ordered.
1,851
5,554
Cliftonville
A Class Burstner
Since 2014
If you do put it out, make sure you use anchor straps......
We put ours out, pegged the legs and went for a long walk with the dog...a heavy windy rain storm came through and when we got back our awning had collapsed due to wind and water...
Expensive mistake.....
PP Bear
7,800
28,721
Kent, UK
Auto Trail Dakota SE
It's those freak winds and storms that turn up unexpected and uninvited and trash the awning that we all hate. At the Crick boatshow one year and it poured down like no ones business. Mine deploys on the left and was literally buckling under the weight of water, even after having it lowered one end. The hymer beside me had his deployed out to the right and in the "eye" of the storm and it had snapped one leg and completely buckled the frame. Mine would have been worse if it hadn't been sheltered by the actual vehicle. Expense act of god.
Also quite noisy if left out overnight and the wind gets up.
Don't think I've deployed mine in a year. If it's sunny, I want the sunshine, if it's wet, I leave it in as I'm hardly likely to sit outside in it.
Think unless you're suffering in +30's and need the shade, leave it in?
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I use mine all the time. I use a luggage elastic double over the outer end of each roof beam. Each is attached to two heavy cord guy ropes. One guy rope is pegged at right-angles to the front rail & the other in line beyond the end of the awning. Repeat at the other end of the awning. I never, ever, use the awning without the guy ropes in place and I only take it in when the noise becomes unbearable.
Chris
21,051
278,524
None
10 years
Get an Omnistor fitted.
They are better than Fiamma.
Jul 10, 2016
414
385
hucknall
Swift bolero 712sb
10 years
we are amazed how everytime we go over Europe how many people wind out their awnings , some put the legs down some dont, most dont tie anything to them, then go off for the day without a care .
Oct 7, 2013
5,891
36,896
South Wales
Swift Escape Compact
Since 1988
Some yeas ago, when we were real novices, ( we all were once), we were on a site near Lake Maggiore.
We were sat having a glass of wine when we saw the people next to us wind in their awning. We thought they must be thinking of moving on.
When others started doing the same we just assumed that it was a "moving on day".
When the wind suddenly hit we were hanging on to the awning for about ten minutes. We suffered no damage as a result but had to clear up for the next door pitch who were away.
We gathered up their washing, which was spread about the area, and took down the remains of their caravan awning.
We now always take notice of what our neighbours are doing, never leave out our awning when leaving the site and take it in every evening. Maybe overkill, but we still have our awning!
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
A heavy down pour in slovenia last year ripped our awning right off the panel van we had at the time, broke the alloy arms and twisted box section like it was made of cheese, was scary how robust you think these things are and surprising how they snapped and were pulled apart from a down pour, we never leave our awning out anymore unattended.
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
We have gone through a few good storms with our awning and safari room rigged. We use two tie downs in slot in the front rail and a 50mm ratchet strap over the middle of the awning. We always have the mid point rafter fitted and now have a lengthways rafter that fits to the spring arms. Proper set up is the answer, though there is always a difference in the effort for a weekend or 6 months snowbirding.
Aug 18, 2011
12,135
18,001
derbys
AUTOSLEEPER SYMBOL
I cannot understand the use of ratchet straps when used with a spring !!!does not make sense at all,,,,BUSBY:):)
Aug 18, 2011
12,135
18,001
derbys
AUTOSLEEPER SYMBOL
When you use a Safari room the wind cannot get under it the same as just using the canopy so much safer,,BUSBY.
Aug 18, 2011
12,135
18,001
derbys
AUTOSLEEPER SYMBOL
Shock loading, the spring reduces the shock load on the awning mounting point.
I know that but if you are putting flexibility on the straps why the need for ratchets,,,BUSBY.
TheBig1
17,613
43,147
we learnt the lesson about strapping and dropping a canopy, whether fiamma or omnistor. near the sea, you often find the wind gusts at the turn of the tide. have seen many wrecked canopies and damaged vans caused by insecure canopies
Jan 2, 2015
2,470
8,621
Cumbria
Burstner Solano t725
since 2014
How does anyone else secure the straps to the ground? We use a couple of these from pet stores if we can get them into the ground or if not some other immovable object such as the trees or hedges around the pitches in Spain
TheBig1
17,613
43,147
beware those corkscrews as they snap far too easily where the pin passes through it. they are no good at restraining a 20kg dog. no way will they hold an awning if the wind gets up
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Since 2011, previously a tugger
I replaced a broken end cap last year which supports the roller canopy. Held on with just three self tapping screws! Having seen how flimsy they are constructed I would never leave it over night.
Lorryman100
640
1,015
UK/Scotland
Rapido A class
Personally I use them because a ratchet strap by their nature is less likely to slacken off due to the constant tugging from the spring on a breezy day compared to a tied knot or a fold over clasp type arrangement.
Jan 17, 2014
1,249
2,364
Wellington, Telford, Shropshire
Van Conversion
Since 1977
We lost our 3m Fiamma F45s in a sudden torrential storm in June, it popped a leg out and buckled one hinged arm. Has anyone experience of replacing the arms on these awnings? I see that all parts 'should' be available.
I have replaced the whole thing now but would like to look into repairing the damaged one if it is possible.
Rod
makems
3,439
27,697
Ingleby Barwick,,Teesside
Sadly had to give up
We have a 6m Omnistore which is like a huge sail.
I never put it out without 5 (five!) ratchet straps with BIG pegs and a centre support post and wind it in every evening.
HOWEVER there have been several occasions when the wind has got up suddenly and it would have been dangerous to undo the straps to wind it in. Cue sleepless night but so far no damage despite some Very Strong winds in Morocco.
tonyandcarol
522
35,557
Spilsby Lincolnshire
Niesman bischoff Fla
since 2005
had mine up with the safari room many times in strong winds and heavy rain storm straps on the front and the centre bar in and have had no problems. but i would not leave it wound out in strong winds if i didnt have the safari room fitted.
