Ferry ramps
Discussion in 'Motorhome Chat' started by Mikey RV, Aug 17, 2015.
  1. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,108
    3,166
    Devon
    Are the ramps on the ferry from Plymouth and Poole leval for getting on and off. Have just come back from Jersey in the car and the ramp was like going up a mountain, ok in the car but thought if we had the camper I would be bottoming out.
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,775
    11,980
    Plympton, Devon
    You will be fine from Plymouth. I have seen monster MHs with massive overhangs get on and off without problem. Jersey has massive tides so I guess if you catch them wrong the ramp could be steep - and there were Spring Tides over the weekend so the range would have been bigger than normal.
    Hadn't considered before having to consult a tide table before getting a ferry. :)
    • Like Like x 1
  3. Traveller_HA5_3DOM
    Traveller_HA5_3DOM Read Only Funster
    Jul 13, 2012
    428
    326
    Following the Sun
    If you five on at an angle i.e. one wheel at a time I always find it mounts ferry ramps much better than trying to meet it square on.
    • Like Like x 1
  4. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,852
    11,059
    Glasgow
    What like is it getting on the ferries at Dover. I've already damaged my rear by bottoming out and dint want to make it worse.
  5. deanroofing
    deanroofing Funster
    Nov 20, 2011
    289
    249
    bedfordshire
    Never had any problems at Dover, just go on nice and steady.
  6. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,425
    2,672
    Surrey
    We have also never had problems at Dover, and we have a massive overhang. Plymouth also no problems. In fact the only ferry that was a bit dicey was the Isle of Wight ferry ramp at Southampton. Had to take that one very slowly indeed.
  7. LaMB
    LaMB Read Only Funster
    Jun 15, 2012
    69
    49
    Boston
    I have in the past had them move the ramp to a 'reasonable' position before I would attempt to drive over it. They don't seem to like to bother to get the correct angle, but when you are holding up the loading they soon get it done.
    I had an occasion when a ramp was badly angled, and we caught the ground, the guy was quite arsy with me at the time when I complained, but apologised when we were dis-embarking. As they tend to load us with the LGV's, which have better clearance, they don't realise what damage can be caused to our 'lower' vehicles.
    So my advice is, if you are not happy, get it adjusted.
    Martin
    • Like Like x 2
  8. Badknee
    Badknee Funster
    Aug 25, 2014
    3,744
    16,484
    notloB
    Sorry to hear about your rear, was it bruised? :whistle:
  9. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,108
    3,166
    Devon
    Cheers guys, if you see a long tailback it will be me having a standoff with the ferry man, getting him to lower it.
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,568
    9,994
    a mate of mine bent the towbar on his van loading at Portsmouth. the van had a huge overhang behind rear wheels though. ferry company couldnt care less
  11. iandsm
    iandsm Funster
    Jan 3, 2008
    1,633
    2,778
    Suffolk
    How do they adjust the ramp angle. The ship side is governed by the height of the water so is there some way of adjusting the dockside. Just wondering as we have a very low slung unit.
  12. big map
    big map Funster Life Member
    Mar 8, 2009
    2,325
    17,140
    Poole
    Initially a linkspan was a ramp that was attached to the pier at one end and was suspended above the water at the other. The height above the water was controlled either by hydraulic rams or cables, these types of linkspans were less well designed for the various conditions of the tide, wave and current and so were superseded by underwater tank linkspans that through compressed air can be adjusted for ferry ramp height and often need no adjustment for tidal height. The aim of all this is to have the linkspan at the roughly same height above the water as that of the car deck on whichever ferry happens to be docking at the time. All that is then needed is for a ramp (usually on the vessel) to be lowered, bridging the gap between the ferry and the linkspan.
    Look how low the trailer is to the ground the dockers adjust otherwise it would ground
    • Like Like x 2
  13. MicknPat
    MicknPat Funster
    Dec 16, 2007
    629
    3,011
    Touring UK
    Where are you heading for, have been told that the ramp at Bilbao can be little tricky? We go Portsmouth to Santander no problem.(y)
  14. Ranger
    Ranger Funster
    Nov 2, 2008
    232
    195
    Lincolnshire
    Try some of the Scottish ones where you reverse on and they throw lumps of wood under the back end if it catches.
    • Like Like x 2
  15. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,720
    St. Helens MERSEYSIDE
    If the ramp is too steep refuse to use it and you may see a smaller pair of ramps which mysteriously appear from a locker and two sailors put them down for you if traffic backs up during unloading there will be a stewards enquiry from the bridge and somebody will get their ass kicked.:)
    • Like Like x 2
  16. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,108
    3,166
    Devon
    Will be going Plymouth to Roscoff or St malo or Poole to Cherbourg and will not be getting on or off the ferry if I think it will bottom out. To them it's just another motorhome to me it's my baby.
    • Like Like x 1
  17. Spud
    Spud Funster
    Jan 18, 2015
    132
    200
    Nth Surrey
    Recently crossed Holyhead to Dublin on the Stena Supperfast X with no problem. Returned on the Stena Aventurer tow hitch grounded out. Same ramp different ship!
    (As an aside there is no difference in the crossing times of the ships despite the name).
    Spud
  18. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,813
    13,725
    Norfolk
    I fitted grounding rollers on the rear of my RV and they have done their job on the odd occasion.
  19. GAVLAD
    GAVLAD Funster
    Jul 31, 2014
    641
    622
    West Yorkshire
    We did Portsmouth to Caen and Cherbourg to Poole out normal ferry and back fast ferry in our old VW Baywindow.
    Outbound we bottomed it and tow bar took the brunt. We thought we was sat in the space shuttle it was that steep going up the ramp.
    Coming back was better for the ramp but Brittany ferries packed us all in so close Side by side, I felt uneasy about having the van damaged.
    However to be fair, there did look to be a few ramps in use, so will probably depend on which deck they load you on, as there were low loader trucks & trailers and they managed ok.
    • Like Like x 2
  20. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,207
    6,570
    UK
    My mind boggles at the thought of your damaged rear, especially after bottoming it out :ROFLMAO:;):giggler::*:wasntme:
    • Like Like x 1
