faulty toshiba 2450 laptop
Discussion in 'Computers' started by SC 05 OUT, May 10, 2012.
  1. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    Been given my nieces laptop to mend, it hasn’t worked for a while, so mugins offerd to fix it!!
    It boots to the recovery cd ok, the proper set is missing but I have a set that from a very similar machine (both Toshiba satellite p4’s so it should be ok)
    It does the loading of windows bit, but on reboot from hard drive it goes BSOD
    Error STOP )x0000007b ( 0xf9E512640, 0xc000000034, 0x00000000, 0x00000000)
    That’s about it, I did think it might have been the hard drive, so I swopped it out with my portable drive, same problem, and the laptop drive seemed to work ok in the portable housing.
    I’m guessing either board failure? But why will it work with the recovery cd and only stops on booting from window xp hard drive?
    Or bios failure/corruption/virus? But I have no experience there
    Seems a big shame to bin it, anybody got any suggestions?
  2. browne4573
    browne4573 Read Only Funster
    Aug 23, 2011
    61
    21
    north east scotland
    Might be the memory at fault? If it is possible try taking one memory out at a time. Don't bin it, if it won't load windows it will probably load a Linux variant.
  3. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    Im not sure thats the problem as it will work ok in load o/s mode etc and Im sure if memory was playing up it would not get that far but I could be wrong there?, all google stuff seems to piont to hardware change, but there has been none?
  4. bmb1uk
    bmb1uk Read Only Funster
    Jan 1, 2010
    256
    145
    LEICS
    could lend you my long handled 14lb universal fixing tool, usualy mends all things :Rofl1::Rofl1::Rofl1::Rofl1:
  5. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    You would be better off getting a win7/winxp disc and formatting then re-install...
  6. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    ah a man after my own hammer:Rofl1:
  7. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    did do that, I formatted it in my 2.5inch caddy and used an differant xp cd, it loaded the files ok, but on re boot it was the same error code. I do have acces to a win 7 setup disk I could borrow to test but i think the out come will be the same
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,364
    9,811
    Have you tried clearing the BIOS?
    on boot up press Del I think with toshibas could be F1
    in the bios screens reset to factory default
    reboot
    this could however be a corrupted bios and need reflashing with the latest for that model. info on toshibsa support website
  9. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
  10. meexi
    meexi Read Only Funster
    Feb 6, 2012
    89
    103
    Angus,Scotland
    Toshiba`s appear to have a common fault on the graphics chip and sometimes it needs reseating. Also make sure the fan is turning easiliy, To reset the BIOS take the battery out and press the on/off button for 15 seconds.
  11. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Aaah, the British Leyland toolkit...................:Wink:
    • Like Like x 1
  12. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    You didn't need a 14lb anything to crack a British Leyland...a toffee hammer would have done it they were so thin....:Rofl1::Rofl1:
    • Like Like x 1
  13. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    any idea were the graphics chips sits on the mb?
    its gettnig silly now,
    Bois has been reset to default (and back again) it holds the date ok
    harddrive has been out again , did a dskchk and a virus scan (wislt conected to a caddy on my desktop)
    has had umtine instalations from a toshiba disk set, an xp disk, a win 7 disk
    all install ok, but on reboot give the same error.
    looks like I take it misterton to let somebody use it as a ramp (but AS ITS SLIM, THAT WONT WORK EITHER)
    edit: is it possible to flash the bois if you cant boot the machine? Ive only done befor on a working box
  14. TheBig1
    Nov 27, 2011
    7,364
    9,811
    i still think the BIOS is potentially corrupt...did you download the new one and reflash?
    unlikely to be the graphics chip if the screen works to install. I assume it boots from cd ok?
  15. TheBig1
    Nov 27, 2011
    7,364
    9,811
    just taken the time to look up the error code
    its the SATA hard drive controller on the motherboard either incorrectly identifying the drive or a virus/ user error has meant the settings have changed from ATA to AHCI. if updating the bios fails, it is a knackered controller, which is part of the mother board
  16. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    yes it boots from cd and will install windows ok, when it re boots to hard drive that when the problem crops up,
    I havnt flashed the bios as I cant boot the machine, as I understand it the machine needs to book ok befor I can flash the bois or is that not correct
    all the google stuff seems to piont to new hardware being installed ? but this is not the case,
  17. TheBig1
    Nov 27, 2011
    7,364
    9,811
    you can flash the BIOS without windows running. From memory you put the new bios file on a cd or usb thumb drive, set the bios to boot from that and it detects the new bios and installs it
  18. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    Ive ow flashed the bios to latest one, the problems the same, my IT son-in-law thinks the disk controller on the main board has gone, so its scrap.
    Anybody need it for spares, screens ok, 30gb drive, memory stick.
    first to post gets it
  19. browne4573
    Aug 23, 2011
    61
    21
    north east scotland
    Hi, I'd love to have a play with it, I have wanted to try running Linux from a USB drive so your laptop would be fine for that. If you are generous to send it my way then email me on Browne4573 at yahoo.co.uk and I'll arrange to pay for the postage.
    If it doesn't work for me then I'll free cycle it locally.
  20. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    its yours then, pm your mail address and Ill post it to you, no charge tomorrow...if you can get it going shove a fiver in a charity box of your chioce
