Faulty Fresh water sensor (1 Viewer)
43,207
48,802
More to the point....has anyone not experienced it :roflmto:
Even if you do get it working it wont be accurate and WILL fail again.
When the taps run dry you need to refill.....most accurate method there is. :thumb:
Same applies to toilet cassette level gauges....open the flap, if you see floaters it needs emptying.....if you dont its usually safe to 'go'
Feb 16, 2013
19,505
51,186
uttoxeter
ambulance conversion
50 years
Hi all
I'm guessing it's the sensor as it's flashing empty when it's full! Anyone had similar experiences?
Dai:Smile:
Mines the opposite , it says it's full till there's about a cupful left then goes straight to empty:Doh:
Chris69
52
40
Derbyshire
Coach built
since 2006
Hi I have just sent a query to Sargent about a similar problem.
Mine flashes empty when a tap is running water and reverts to normal when tap is closed.
Don't know if it's control unit or sensor.
I am waiting for reply only sent message a couple of hours ago.
Chris
RS_rob
1,010
669
Turnford
over a Year Yay................
Mines clever I can press the button & see a full tank & then press the button again & we need to refill as the tank is empty one more time & the tank might be full again :ROFLMAO:
