Fault code P0481 on fiat chassis
Discussion in 'Base Chassis Section' started by Grahmes, Oct 15, 2016.
  1. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    hi all, we have an yellow engine management light on the dash.
    The fiat garage have told me it is code P0481 for cooling fans 2-open circuit.
    Does anybody have an idea what this is about before it potentially costs a fortune. It came on whilst in France and have completed 2000 miles since- does not appear to cause any issues.
    Thanks in advance
  2. Larby
    Larby Funster
    Jun 17, 2012
    1,718
    3,993
    North Essex
    Plug loose or come off?
  3. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    I have tried looking - nothing obviously loose
  4. Newfie
    Newfie Funster
    Jul 5, 2016
    76
    43
    Essex
    • Useful Useful x 2
    • Informative Informative x 1
  5. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,100
    9,724
    Lorca,Murcia,Spain
    Your radiator fan isn't working for one reason or another as @Newfie has linked to.
  6. Badknee
    Badknee Funster
    Aug 25, 2014
    3,736
    16,428
    notloB
    You should be fine in the cooler weather but may get increased engine temp if stood for any length in traffic or climbing a lot.
    Get it looked at asap but imo not a very major problem if you keep an eye on temp gauge.(y)
  7. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    Thanks guys - still looking
  8. Xabia
    Xabia Funster
    Jan 20, 2011
    758
    500
    Rural Nottinghamshire and Spain
    Join the club! My EML light comes on when I climb the Pyrenees or switch the air con on. Diagnostics reports that the second fan is not coming on when it is, you can hear it kick in when stationary and it certainly works when mountain climbing as the temperature never goes up very much. As I had found two,points where the loom to the ECU was rubbing on metal points I insulated those areas and hoped it would cure the problem - it didn't.
    I now carry an OBD reader with me and delete the fault code until the next time.
    • Like Like x 1
  9. Newfie
    Newfie Funster
    Jul 5, 2016
    76
    43
    Essex
    Hi @Grahmes
    Did you get it fixed if so what was the problem
    • Like Like x 1
  10. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,684
    3,265
    Cumbria
    As a stop gap if your temperature gauge starts to rise, put your heater to hot and the fan on full power, used to have to do it on long inclines when tugging.
    • Like Like x 1
  11. Xabia
    Xabia Funster
    Jan 20, 2011
    758
    500
    ignore my post, replied in error.:cry:
  12. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    No it is not fixed yet; we have been away - not yet caused any problems with engine temperature over the last 700 miles his week.
    Will be going to the garage in the next month. Not going too far in the next month, so should be able to get it sorted
  13. Xabia
    Xabia Funster
    Jan 20, 2011
    758
    500
    Did you find the cause and get it fixed?
  14. mexican pete
    mexican pete Funster
    Nov 6, 2012
    29
    54
    Guildford
    Snap. Climbing up the motorway from Perpignan into Spain my engine management light came on. Took it to a Fiat dealer who diagnosed that the second cooling fan was not switching on. He short circuited the 2nd fan and lo and behold it worked . He downloaded new software but still no joy. He reluctantly gave up as he said the ECU needed replacing. He did reset the dash light. Stayed off until I got caught in a massive traffic jam on the A1M. Luckily my mate has a diagnostic box so was able to reset it again. I'm going to wire the 2nd fan in parallel with fan 1 so hopefully no more overheating.
    • Like Like x 1
    • Useful Useful x 1
  15. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    No, not fixed yet- booked in for 10thJanuary - it's staying there until sorted.
    Nothing seems loose and is beyond me.
    Will update when fixed. Happy new year all
    • Like Like x 2
  16. LOOSE WHEEL
    LOOSE WHEEL Funster
    Mar 31, 2015
    61
    55
    WORCESTER
    Wireing second fan off first is a good idea but never wire one direct of ignition systems as there only designed to run in 20-30 second bursts.
    If you run them permanently the bearing collapses.
    Saying that thay do last a few hours, when needs must.
    Andy
    • Useful Useful x 1
  17. Xabia
    Xabia Funster
    Jan 20, 2011
    758
    500
    As a matter of interest does your EML illuminate when you switch your air con on. Mine will do that if I turn the a/c on when stationary after a few seconds. Strange thing is that although the Fiat diagnostics say the fan isn't working it is.
  18. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    One fan works with AC.
    The EML light is permanently lit.
    Even in southern France last year- the engine temperature never went up.
    Just need to know what is going on!
    • Like Like x 1
    • Thanks Thanks x 1
  19. Grahmes
    Grahmes Funster
    Oct 2, 2016
    18
    9
    Devizes
    The management light is sorted, it needed a new throttle body-there was another error code as well as the first.
    The cooling fan code was on because of the newer code was confusing other electrics.
    I'm confused- let alone the vans electrics!
    • Like Like x 2
