Fanmaster Heating.
Discussion in 'The Beginner' started by jaykay, Oct 13, 2011.
  1. jaykay
    jaykay Read Only Funster
    Aug 19, 2011
    199
    183
    North Lincolnshire
    Hi,
    I could do with some help with 3 queries/problems I have.
    1. I cant get the Fanmaster heating going on my new baby :cry:
    It has a 240v socket to it which is fine. I have pressed the reset on the right hand side and this was fine.
    I have put the controller to fan and elec slow, with the dial on full but it does nothing. The selection led's just flash whichever one is selected.
    Am I missing something, or is it likely the main board needs replacing ?
    I cant get the old gas fire to light either, but dont think this should effect it should it ? I have no manuals so am guessing at all this.
    2. The fridge has power (rocker switch light up green) and I can light it on gas, but I hear no motor and it doesnt seem to be getting cold.
    3. The water heater is making piping hot water via the mains without the "cascade 2" switch in the on position. Is this switch just used for gas operation ? When I switch this on (with mains on as well) it lights green, then goes to red. Can anyone advise the correct operation for this ?
    I have the motorhome connected to the mains.
    It is quite likely that the van has been stood for a long time, is there anything that may have stuck ?
    Ticking them jobs off one by one ! :thumb:
    Heres some images of the offending articles to help identify which models etc.
  2. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,753
    3,254
    Eastbourne East Sussex
    I can't help with the fanmaster but
    2. A 3way fridge doesn't have a motor so you won't hear one. Give it a while to get cold (say an hour)
    3. The switch on the carver water heater is just for gas, there should be a switch for mains elsewhere which usually is just a domestic type switch with a neon indicator. The green light which changes to red indicates that the gas has not lit, try it a few times but if it continues and you have gas it looks like the thing is faulty. Do check there isn't a gas shut off valve somewhere that is closed first.
    Just a point with the fanmaster, it will only blow hot if the heater (which you can't light) is working. It is basically just a fan to circulate hot air though it does have an electric heating element. Check the mains fuse as if this is blown the lights on the control panel (which is 12v powered) will still work.
  3. motorhomelover
    motorhomelover
    Jul 28, 2010
    1,719
    613
    The world
    when you light the fridge on gas you should see the flame in the sight hole (bottom rear inside fridge) if you put your hand over the outlet (outside of the van) you should feel it is hot if the fridge stays warm it may need re-gassing
    onn12 volt it will only work when the power is coming for the engine it will not work on the leisure battery.
    hope this helps
  4. jaykay
    Aug 19, 2011
    199
    183
    North Lincolnshire
    The fridge has been on for a few hours, and doesnt seem to be getting cold. The vent outside is also cold so it looks like a regass may be in order ?
    Any idea on cost and where to get done ? Is it best to remove fridge and take somewhere ?
    I have had it lit on gas, and could see thro the viewhole.
  5. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,173
    16,633
    Liverpool.
    You will be VERY lucky to find someone to regas a fridge. They are full of amonia and its not allowed any more. Try taking it out and turn it upside down overnight and keep giving it a turn. If your lucky you will hear the amonia gurgling and remixing.
