Fan Heater (1 Viewer)
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
I have a fan heater which I would like to use for supplementary heating in the motorhome. The rating on the back of heater says: 230-240V ~ 50 Hz 2200-2400W. If we are on EHU and have this heater on and nothing else apart from the internal lights is it likely to trip?
old-mo
Extra Special
16,343
93,562
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
I should imagine 2200 - 2400, you would be pushing your luck...
We use a Delongi oil filled radiator...
Not tripped any where "Yet"... :thumb:
MikeD
3,936
3,697
London
IH PVC
Since 2012
If I remember my college maths correctly 240v and 2400w = 10amps
So it would depend on your location as some sites only give a 6 amp supply.
I hope that helps :thumb:
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Best plan is to go to a caravan / motor home accessory shop and look for one specifically for the job - they are usually 750 wat and 1500 watt switchable and a thermostat - you would be able to run 750 watt on the majority of sites without worry and use other items as well
G8WVW
92
67
Cumbria
C class
Since 1990 on/off
Fan heaters usually have two heat settings; use the lower heat setting and you'll be fine. Probably only a kilowatt on low.
Cheers.
JohnM
650
179
Central Scotland
CClass
Since Feb 2009 and 40yrs c/vaning
I would go for a small oil filled radiator from argos thats what we use and they are silent and dont dry up the air as most fan heaters do.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Allow, very approximately, 5A for each kW then you'll be sure of staying on line.
I think you've three choices for room heating.
Oil filled rads are nice and silent, for light sleepers, but take an age to get the room up to temperature and may dump the oil unexpectedly.
Fan heaters distribute their heat relatively quickly but are noisy.
Silicon bar fires are quick, because they heat the objects in the room not the air eg. you, and they are silent but they make you feel like your eyes are burning when used in a small space.
Hope that's not just confused your decision.
Ed
