extra lighting
Discussion in 'Tech/Mech General' started by voyager 1, Feb 4, 2014.
  1. voyager 1
    voyager 1 Read Only Funster
    Oct 25, 2012
    92
    35
    Durham Tees valley
    Just wondering how i an put some more exterior marker lights on the van like you see on some trucks. Used to have them on my old vans but this one has something called a canbus system so i am unsure about adding any extra lighting in case it confuses the ecu causing it to shut down or something, I am not to nolagable with modern vehicle electronics
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,920
    1,944
    Warwickshire
    Side marker lights are a mandatory requirement on longer vehicles, so the manufacturer will have fitted as many as are required. (Or are you telling us that Swift forgot to do it?)
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,099
    17,769
    YO11 2BD
    if the existing marker lights are canbus controlled you cant safely add more.....but i doubt they are canbus controlled.
    Canbus is generally for mandatory road lights....head and tail/brake and indicators.
    If it is canbus and you add to it you would need to add a bypass relay to the side/tail light circuit.....which is a pain.
    Best option....You could add extras and wire them to a seperate switch but would need to be powered from an ignition switched live source so they dont get laft on.
  4. cronkle
    cronkle Funster
    Apr 18, 2008
    111
    47
    shropshire
    Hi,
    Side marker lights are not required on a passenger vehicle even if it is over 6 metres long.
    If you do fit them here are the positioning dimensions as in the appropriate regulations.
    http://www.legislation.gov.uk/uksi/1989/1796/schedule/9/made
    My van has a fuse within the habitation fuse box which controls the side marker lights. As I understand it quite a number of other vans are rigged the same. You might want to explore that idea.
  5. Allanm
    Allanm Funster
    Jun 30, 2013
    3,185
    4,342
    Cotes d'armor, France
    Or you could just fit some really good reflectors....
    Allan
