Extra Lighting (1 Viewer)
paul18
171
34
Somerset
C class
newbie, but was caravanner for 20 years
Hi Guys, how difficult would it be to wire in a couple of extra 12v interior reading lights?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
On a scale of 1 to 10 ---- 0.
Well it depends. Routing the wires neatly is an art and luck is involved. Usually there are enough cupboards to hide them.
Current wise, a non-problem, modern LEDs take so little current you can splice into any 12V you can find.
paul18
paul18
171
34
Somerset
C class
Sounds simple, bet it isnt. Lol
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Find a 12V feed is stage 1. This could be the leisure battery or another light. Then plan a route to your required new light location/s.
If wired off another light you can just join the two wires ( it will already be fused ), if going to the leisure battery then fit a 5A fuse right next to the battery +. The type of flexible wire you see on mains lamp will do or even similar sized loudspeaker wire.
paul18
paul18
171
34
Somerset
C class
As I understand it then, If I find a 12V outlet I can splice into it using scotch blocks, red to red and black with LEDs. I want 2 extra lights, can I daisy chain them on?
andy63
4,672
15,017
south shields
None
since 1990
That's should do....as Brian mentioned above if you are not coming off an existing lighting circuit ( sounds like you might be considering a 12v socket feed )then a fuse would be best fitted...
I hate those scotch lock connectors...I'd splice in with a soldered connection or use a different connector..but that's just me
Ta andy
paul18
paul18
171
34
Somerset
C class
No, not a socket feed, there is a reading light by off side window, from which I can spur along to swivelling cab seats, where I want a reading light above each as its a bit dark that end
3,872
5,274
The City of Henlow
Adria Supreme
Since 1980
I would also like to extend my 12v lighting and fit a strip of LED lights above some cupboards, but what current would a metre strip consume? Would it be anything like the old quartz halogen consumption if the strip has around 20 LEDs?
Gellyneck
9,234
18,207
Scotland
More than toes wet now!
Can you not connect the new cable to the +ve and -ve connections on the existing light fitting and run to required position?
Bailey58
8,811
29,531
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
I needed an extra ceiling light at the front of the lounge in the Bailey where it was dark in, well, in the dark. Accessed the spotlights at the front of the cab and fed off there but the real difficult bit was feeding the wire across and above the ceiling, I forgot about the near solid poly insulation and near impossibility of pushing a feed through from the inaccessible corner. Swallowed twice then cut the hole in the ceiling and fed a probe through from there to the corner. Only took a day and a lot of swearing. :LOL:
andy63
4,672
15,017
south shields
None
since 1990
Nothing like the current draw....I checked a 5m strip of led's a little while back and the current draw was a max of around 1.25A with the whole strip lit. That's just an example other types may vary but lot less than the halogen for the equivalent light..
Ta Andy.
O
Old Soldier
All my external lighting has LED equivalent light units and very good they are. I also fitted some LED strip lighting to Elle last year as mood lighting. Still working well. As you can see, they give a choice of background colours. No good for reading etc but great for watching telly or warming the atmosphire on a gloomy evening.
Lenny HB
53,421
149,954
On the coast in West Sussex
Hymer B678 DL
Standard wiring is +blue, -white (brown in Hymers) or any colour the manufacturer decides to use.:)
Do check the polarity with a meter before connecting.
