Extra leisure battery (1 Viewer)
Jul 13, 2011
287
37
Stoney Stanton
since 2010
I am about to fit an extra leisure battery to my Pilote motorhome and would like to know what the piece of plastic tubing does that is attached to the existing one. It is obviously some sort of drain/overflow but where would it be vented to? Would i need to fix the same sort of tubing to the new battery.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
It's a vent to go outside the vehicle. Get rid of hazardous gasses.
If new battery does not have one it must be a sealed one.
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
If the new battery does have a vent hole in the side you'll need to Tee in to the existing one.
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
I am not sure if they really help, the gas given off is Hydrogen, the lightest of gases and the pipes go down not up. One suspects if the pipes fit properly they will become full of the very gas you are trying to get rid of.
Jul 29, 2013
9,071
18,518
Salisbury
Hymer B678DL A class
since 2011
I suppose as they become full it will trickle out of the end but still leave the pipe full
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
It is not to get rid of the gas as such.. merely somewhere for excess gas to vent to out side the hab area
And as the battery cools any gas in the pipe will be sucked back in to the chamber :)
Fully sealed batteries have an expansion chamber build in.. A bit like a collapsed balloon
Gas goes in to it and is then drawn back in to the main body
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Perhaps, but as hydrogen is a very small molecule the seal has to be very effective to keep it in at all, does a bit of lose fit polythene fit the bill
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
If it is a loose fit it is not correctly fitted..
A correctly fitted vent pipe does the job just fine HD is not exactly a porous substance !
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Carried along with the vented gases, if the battery is undergoing a high charge rate, is very acidic water vapour . That stuff is most definitely better out of the van than in.
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
You aint wrong there Tony !!!
