Extra battery (1 Viewer)
ips
506
4
Low profile
Have always camped, caravaned or had boats. Now in our second year with the motorhome.
OK...... following on from solar thread what about instead of solar panel fitting an additionall 85a leasure battery, presumably that would give me double the usage ?? Just wire it in parralel to existing battery ???
Only problem would be were to fit it cos would need heavy duty wire I spose so would be a long wire to garage.
Any thoughts...good idea...bad idea....etc etc
Ian
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Always a good idea fitting extra batteries:thumb: and solar too in my opinion
But it should be located so as to minimise the length of cable reqd
ie as close to the other as possible
ips
ips
506
4
Low profile
Yep thats what I thought could be difficult though cos current one is under passenger seat. Could prob fit one under bonnet on a bulkhead but still got 5' or so of cable ?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Ian
The problem is just like a fuel tank, you can double it's size and go twice as far then you have to spend twice as long filling it. You have to match income to outgoings.
Where you put it is not important. Most of the time you only draw the odd amp or two and voltage drop is not a killer.
ips
ips
506
4
Low profile
I am confused as to solar panel or battery ????
DESCO
2,646
266
London
low profile
18 years +12 years tugging
I would say both if you intend going without hook up's
Dave:thumb::thumb:
ips
ips
506
4
Low profile
Dave:thumb::thumb:
Spose that definately coversit then but what is minimum size of solar I require just to trickle charge during the day.??
DESCO
2,646
266
London
low profile
Not certain have not gone that route yet, but someone is bound to know.
Dave:thumb::thumb:
ips
ips
506
4
Low profile
Dave:thumb::thumb:
Thanks :thumb:
BigJohn
187
Kiveton Park, S Yorkshire
Low profile.
3 yrs long, long ago
I've just had a 130 watt solar panel fitted on the roof, and a 300 watt inverter (just for the 19" LCD telly). Solar panel charges the 85 amp leisure battery only, NOT the vehicle battery.
I queries if one leisure battery was adequate and was told to suck it and see. Good advice I think.
This was advised by South Yorkshire Motorhomes, and seems to me to be good advice.
I switch the inverter off when telly not in use.
I'm off up Scotland on Monday the 7rh September for a few weeks - that'll be a good test.
If I find that I need another battery, that's easily enough done.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I think you will find that you are wasting power and running your existing battery low at times with nothing in reserve. 2 x 110 amp/hr batteries will complete the setup for you.
43,323
49,433
if you just want to trickle charge get one of those dashboard solars.....total waste of cash unless you leave it connected at home/storage while not using the van.
trickle charging wont top up your battery..only maintain it if its not being used.
ideally you need to put back in what you take out each hour..
10ah out...10ah in, but of course most of the day you aint drawing anything from the battery so it does get chance to recover.
i have a 330ah battery bank and a 120w panel which gives me about 6 to 7amps per hour in good sunny weather.
this just about covers my battery usage for an average evening....lights, TV, sat box, water pump etc.
a couple of days without sun and i start to suffer lowish battery reserves but then i run my genny:thumb:
id say a couple of 85ah batteries would need a minimum 55/60w panel to keep on top of them depending how power hungry you are.
if i allow my batteries to get to a very low, and not advisable, 50% charge it will take, theoreticly, 23.5 hours of strong sunshine to charge them fully from my panel at 7amps or 6.6 hours from my genny at 25amps.
The Wild Ones
76
Oxfordshire
Fledgelings
I have had installed an extra battery (180ah in total) together with two solar panels (163w in total). I deliberately added more solar for winter use, when less daylight is available and hence battery drain will inevitably increase as a result.
Our two week holiday recently was a great success with regard to battery power management with no EHU used (or needed) for the entire duration. :Smile:
