External USB Point ? (1 Viewer)
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
I am looking to fit an external USB point similar to those available for TV and Satellite connectors, any about? :Smile:
14,737
75,958
UK
Self Build
14,737
75,958
UK
Self Build
Quite like the look of this as well
Broken Link Removed
Feb 27, 2011
14,737
75,958
UK
Self Build
What about this one then: Broken Link Removed
Ian
They look really really good :thumb: but no electronics in the back to provide power from 12v.
I am presuming the OP wants this in his van for charging stuff?
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
What I want is an external connector to run my wifi antenna cable into the motorhome, sorry if there is any confusion.:Smile:
I used one of these to bring the wifi cable from the antenna in. You leave the USB plug on and a waterproof gland fits around the cable.
Broken Link Removed
Jul 29, 2007
6,551
39,655
Ipswich
RV and PVC
30 years
You want an IP54 rated connector or better. Can't see anything at the moment.
Ian
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
I fitted one of this inside my van. I have since found cheaper ones but the advantage of this model is it is designed for boats and comes with a cover which I would describe as at least splash resistant but I am not sure if it is fully waterproof. Which is of course the problem you are going to have if you mount it externally. However, fit it with a separate inline fuse and it shouldn't do any harm if it goes phut.
Other suppliers are available, I can't remember who I bought mine off but this will give you an idea what to look for.
http://www.piplers.co.uk/blue-sea-systems-dual-usb-charger-plug-10466
The advert shows two types, it is the one with the threaded bit and two spade connections you want for mounting in a panel, not the fag lighter version.
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
ah gotcha. Not seen one of those but will look round.
This is the only thing I can see immediately.
Broken Link Removed
That looks as though it has a nut behind the cap so might be a through panel fitting - ideal if so. An alternative is to buy an outlet box intended for a mains socket or a gas outlet (the mains ones at least are available without a fitted socket) and use the waterproof extension mentioned earlier in this thread coiled inside it.
Addie
Trader - Motorhome Wifi
Oct 15, 2011
553
834
York
We can do waterproof IP67 Ethernet (CAT5) adapters - but the USB ones are pretty expensive so we don't carry them.
