External shower
Discussion in 'Motorhome Chat' started by octopush, Jun 24, 2014.
  1. octopush
    octopush Read Only Funster
    Sep 28, 2012
    133
    51
    portsmouth
    I want to fit a external shower to my autocruse starblazer 04.
    Could anyone tell me if the pump works from pressure relief or is it triggered from a micro switch when the tap is turned on.
    Thanks Rob
  2. scotjimland
    Jul 25, 2007
    28,934
    25,589
    don't know.. but a quick look under the sink will reveal all..
    wires to taps... micro switch operation..
    no wires.. pressure operated..
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,967
    2,799
    Kendal, Cumbria
    If it runs on briefly after the tap is closed you have a pressure system.
  4. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Just had a thought..
    Do you know if it's a submersible or a Shurflo type that is mounted outside the tank ?
    Submersible pump will usually be controlled by a micro switch on each tap , although that's not always the case, as they can also be controlled with an in-line pressure switch..
    Shurflo type are controlled by a pressure switch on the pump body.
  5. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    The pump dose run on after the tap is closed for a few seconds.
    The pump is outside the tank.
    Thank you all for your help it looks like i have a pressurised system.
    Makes fitting a external shower a lot easer as i will not have to run a switch to it
