External pump on Autotrail (1 Viewer)
My Dog Likes Fishing
379
407
Lancashire
Hymer B678
Hang on while I look at my watch
A bit of know how needed over here please.
I have a Autotrail Scout 2006 with a psu 2007 panel fitted. On the control panel it has an option for an external pump. Does anybody know where the external pump connection is?
If there isn't one where is the best place to fit one and do I wire it to an existing loom?
Thanks in advance
golly
2,003
69,401
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
What water fill system is fitted? Our auto-sleeper has the truma ultraflo system, on the panel the internal pump is the normal pump to the taps, but if you have external pump selected, you can fill from a container via a submersible pump, the connection being part of the fill hose. John
379
407
Lancashire
Hymer B678
Thanks John,
It is the Truma but where do you plug the submersible in? Is it an after fitting?
golly
2,003
69,401
HYMERCAR PVC
since August 2009
I have a hose with the truma connection on one end and submersible pump on the other. I will nip out and take a couple of photos, won't be long.
golly
2,003
69,401
HYMERCAR PVC
since August 2009
photos, The electrical connection is part of the hose connecter which plugs into the filling point.
John
Scout
3,957
120,762
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
I had a scout for 4 years, but have never worked the outside pump bit, theres no power outlet on the outside for such pump?.
you would expect a two pin 12volt outside socket but there isnt one?
perhaps its just a generic control pannel, used on differant males of motorhome
43,289
49,223
obviously Autotrail haven't wired a dedicated external 12v pump circuit.
cant see the point of an internal switch for an external pump as you need to be with the water container while filling the onboard tank for when the container is empty.
Apr 27, 2008
11,837
14,057
Eastbourne East Sussex
Hymer low profile
Since 1972
I use a length of water hose with a submersible pump on one end (the cheapest I could find, about £6) an in line switch (like a table lamp) in the cable and a 12v plug that plugs in in the kitchen area with the cable out the window. Works fine and I think total cost was less than £10.
379
407
Lancashire
Hymer B678
Thanks for all your help.
John many thanks for the pictures I understand now. :thumb:
K9Brian
605
575
South Manchester
Since April 2010
I did exactly the same as reallyretired but having no handy 12v sockets near the fill point I used croc connectors onto the hab battery in the outside locker. Really handy for sites where you can't get near to the tap for filling up.
Minxy
32,621
66,438
E Yorks
Carthago Compactline
Possible alternative depending on if you want something that can have a 'dual' purpose:
Broken Link Removed
Apr 7, 2021
201
90
Solihull, UK
Autotrail Mohawk
Fairly New
Resurrecting an old thread here, but it pays to search. So if there is no external whale port on the van but the control panel has both the 'external/internal/both' pump selection and (here's the kicker) 'water tank fill' selection, Autotrail have just been lazy and fitted a CP with those options even though there is no external whale type fill port? I can only find the standard 'hose in the hole' water tank fill port.
