external gas point (1 Viewer)
Dec 4, 2012
1,070
1,296
leicester
swift kontiki and vw cam
15yrs
Any suggestions as to where or who do I go to to get an external gas point fitted to my van. Preferably not too far from Leicester
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I had a Bullfinch gas point fitted by Mark (CLS). He travels to you and is based in Nuneaton.
http://www.central-leisure-services.co.uk/
I have also had gas work done by Steve Ash (Home-Serve Motorhome Services) who is also based in Nuneaton and travels to you.
Link Removed
Both are Funster traders and offer 5% discount.
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
Perfect job for bills fix it meet:thumb:
Lucky one
Dec 4, 2012
1,070
1,296
leicester
15yrs
Yes that sounds good :thumb: but what I forgot to say mousy is that I have a gas tank and not bottles and think it is probably a job for a man with qualifications. I only bought the van a couple of weeks ago ,with half a tank full of gas, and have not had to put any in yet . I have absolutely no idea what is involved :Doh: can it be done by a kind hearted man with a screw driver and a blow torch ?:ROFLMAO::ROFLMAO::ROFLMAO: :Eeek: Or mabe there will be a suitably trained person in attendance in which case I will put my name down immediately and I will try and think of something useful that I could do in return.
TheBig1
17,619
43,205
it really is a simple enough job. the hardest part is having the balls to cut a hole in the van wall. once its in and waterproofed using mastic tape and stainless steel screws, its just a case of teeing into the nearest low pressure gas pipe. could be the feed to the fridge, oven or heater. I would also include an isolator valve too, just in case the bbq point develops a slight weep through continued use cooking up all those barbies
i would say give it 2 hours or so and it should be fitted. these things often take longer planning where to fit and emptying lockers than doing the job
Nov 10, 2012
900
8,542
Lincolnshire, UK
Just looking
Had one fitted at John Cross this week:thumb: excellent job done:Smile:
Why not have a few days away ,great site near by , drop the van off and have a day out , return , job done.
Also they are very nice people to deal with :winky:
5,936
38,891
Uk
I fitted a bullfinch bbq point and as TheBig1 said it takes longer to work out where to put it and where to get feed from and where to run pipe, I also fitted shutoff valve after teeing into cooker feed. Easy job though. I made a pipe former from different sized washers,so pipe fits between washers to stop pipe flattening when bent.
