Exterior Side Panel Fixture Failure
Discussion in 'Motorhome Chat' started by Tincataylor, Jul 9, 2014.
  1. Tincataylor
    Tincataylor Funster
    Jul 9, 2012
    395
    722
    Devon
    This was going to be an easy fix, or so I thought but it has turned into a bit of a problem. On our A/S Nuevo the female half of the gas locker door stay is fixed to the side of the camper with two screws, that accepts the male half that is fixed to the locker door. The purpose of the whole thing being to keep the locker door in the open / upright position while the user is accessing the locker. Over time these screws have become loose and it is not possible to tighten them as the holes in the side of the van no longer have enough "meat". A larger diameter screw is not really an option as the existing ones are about as big as you can go with such a short screw. I thought pop rivets would be the answer, but once again the side panel of the van is not strong enough and they popped out with very little effort. It would be a simple matter to replace the self tapping screws with a machine screw and nut if it were not for the fact that the van side is double skinned.
    I am coming to the opinion that I will have to strip away the lining inside and then drill a hole large enough for a nut to pass through and then affect the aforementioned repair. Naturally I am loathe to do this; do any of you bright people have a better idea?
    One last thought, could I blank the existing hole off by bonding a round piece of plastic the size of the existing holes (or possibly bigger) and then drill a smaller hole and then re-fit the bracket with smaller screws? If this is an option what adhesive have people found best when working with GRP
    Many thanks in advance for any suggestions you may be able to come up with,
    Tinca
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi you can get some plastic plugs (with large heads) for fixing trims in cars that you simply push the center pin in---remove the pin and replace with a screw--The plug could also be stuck in position --no idea what they are called but someone will be along with probably a name and maybe a link ;)
    terry
  3. ukbill
    ukbill Funster
    Nov 3, 2011
    4,908
    4,870
    benidorm
    like terry said use a plug but if thats not going to work look for a plaster board plug some open like a umbrella for cavity walls maybe they will help ta van will have cavity walls so they should
    • Like Like x 2
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    They are called panel clips or Rokuts Terry (y)
    But there are other answers too, such as butterfly bolts and other cavity wall fixings :)
    Google cavity wall fixings and have a look ....
    EDIT !
    Beat me to it !
    • Like Like x 1
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    The bike is getting delivered today John (y);)Fully serviced and MOT ed yesterday :D
    terry
  8. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,884
    5,147
    Guisborough
    Has the van body got insulation inside the fibreglass skin if so this might prevent the cavity type expanding fittings from working. I would glue a wood or fibre plug into the hole and then screw into that Araldite/Epoxy glue should be OK if the insulation is Polystyrene dont use any polyester resin or bodyfiller as it eats Polystyrene.
    Martin
  9. Tincataylor
    Tincataylor Funster
    Jul 9, 2012
    395
    722
    Devon
    Many thanks for all your helpful replies. In the end a good old fashioned rawlplug seems to have done the trick...................now why didn't I think of that in the first place???......DOH!!!
    Tinca
  10. buckby
    buckby
    Sep 6, 2013
    213
    148
    nottinghamshire
  11. The Wino
    The Wino Funster
    Mar 23, 2012
    1,160
    2,074
    leicester
    Had a similar problem I squirted epoxy into the hole drilled it when set then put in a screw (although was very careful after when using the fitting!!
    David
  12. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,637
    3,190
    Cumbria
    You can get fixings called Rivnuts, you’re supposed to use a tool to insert them but you can tighten them in with a nut and bolt. I used them for a few fixings on my old caravan when self tappers had pulled out.
