Exterior PowerPoint
Discussion in 'Motorhome Chat' started by Vlad The Impaler, Nov 18, 2012.
  1. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Seeing as my van is parked at the side of the house I think it's about time I fitted an external power point.The plan is to put one of the tube style heaters in on a timer when we get cold spells.
    Are these the kind of things I need?
    http://leisurekings.co.uk/Electrical/?gclid=CKH_4bqb2LMCFcbLtAodE3kAsQ
    Under the section mains connectors I assume ill need the waterproof socket,is it the waterproof connector or coupler that goes into it?
    Thanks Vlad .
  2. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,012
    2,798
    Englishman in Mid Wales
    Yes that's what I would get and I think its the waterproof connecter you need:thumb: all seems pretty cheap as well:Wink:
  3. Scout
    Scout Funster
    Apr 4, 2009
    3,402
    9,476
    doncaster
    its the socet you need, then make up a short lead to power the van:thumb:
  4. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,288
    3,732
    walthamstow east london
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,891
    23,610
    Narrfoook
  6. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    And us , we just plug our lead in an adaptor and plug in the garage, my mate has a fixing outside to do the same. Pete
  7. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,700
    10,394
    Norfolk and Toftir.
    I used an outdoor waterproof socket, handy for other outdoor stuff too. If you have a 13amp socket indoors near enough in the right place you could take a feed off it through the wall.
    • Like it Like it x 1
  8. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    Initially I installed an outdoor waterproof socket similar to the one Rob shows but then found that the connection on the short adapter lead to the main EHU lead wasn't waterproof. As a result I then fitted a commando socket similar to the one mentioned in the OP and that works fine with the EHU lead plugged directly into it.
    By coincidence, Aldi have a double socket as one of their specials at the moment.
    Whichever you do make sure it is protected by an RCD. I think that legislation now requires any permanent installation to be fitted by a qualified electrician - which is why the Aldi (and similar) kits come with a plug-in RCD so that an amateur can fit the socket and then plug into an existing internal socket.
  9. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,070
    3,470
    Eastbourne East Sussex
    This is the one on that site, but needs the special waterproof plug to go with it. If you have to make up a special lead anyway it would be better to put in an ordinary 3 pin waterproof socket which you can then use for lawn mower/pressure washer/ whathaveyou as well.:thumb:
    http://leisurekings.co.uk/WATERPROOF-SOCKET.html
  10. Vlad The Impaler
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Thanks for the advice thus far,I had looked at the waterproof 3pin sockets but when the plug is in the waterproof flap is up ,this is ok for short jobs in the garden but not suited to long term usage,or is it?
    Assuming we get a prolonged cold snap I would have the van plugged in for possibly a week or more,so would want a watertight connection.At the moment I run a lead from the outside store round the house over the fence to van just want to a more suited fix.
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    We have a water feature plugged into just such a socket, been working for about 7 years without problems :BigGrin:
    The van is plugged into a normal 240 v plug in the garage via the eBay type lead :Wink:
    Terry
  12. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,926
    YO11 2BD
    presumably you mean this one
    [​IMG]
    thats all you need outdoors but put a little silicon mastic around the socket when you fix it to the wall, just plug in your normal hookup lead or make up a short version of the same lead.
  14. pappajohn
    Aug 26, 2007
    30,258
    17,926
    YO11 2BD
    think about your normal van hookup point, that may be connected for a week or even more in all weathers.
    the 'sleeve within a sleeve' design of the plug and socket makes it very weatherproof when in use.
  15. Vlad The Impaler
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Yes pappa join I realise that,it's the traditional plug socket my doubts are with.You don't see many of them at campsites.When I said 3pin I was referring to the traditional waterproof socket mentioned by others.
  16. pappajohn
    Aug 26, 2007
    30,258
    17,926
    YO11 2BD
    My mistake.....I assumed you meant the 'blue' plug type sockets.
    look on ebay etc for IP66 rated outdoor sockets.
    IP66 is dust and powerful water-jet proof and will be more waterproof than you'll ever need at home whether in use or not.
    they generally use a standard 3 pin plug and the enclosure and lid is the waterproof part
  17. Vlad The Impaler
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Hi Pappajohn just looked at an Ip66 unit and I can see it being dust and water jet proof whilst flap is closed,however when in use flap is up therefore connection vulnerable .Good for short term use whilst dry not well suited for leaving van on hookup in all weathers.
  18. pappajohn
    Aug 26, 2007
    30,258
    17,926
    YO11 2BD
    You misunderstand.
    the lid is closed at all time except when actually plugging in or unplugging.
    the plug flex protrudes from the small hole at the bottom of the casing, which has a rubber seal, and the cover closes over the plug to ensure a water tight seal all round.
    [​IMG]
    [​IMG]
  19. Vlad The Impaler
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Thanks for clearing that one up for me I see how it works now .I can see the advantage of buying one with an rcd ,drilling a hole through the wall and plugging into an existing socket .
  20. pappajohn
    Aug 26, 2007
    30,258
    17,926
    YO11 2BD
    your existing house ring main will probably be protected by an RCD device anyway...simple to check, if the fuse box has 'push to test' type breakers or an RCD main switch.....if it does then no need to buy an RCD version.
    if it has MCB (non testable) trips or fusewire type fuses (how old ? :Eeek:) and a basic on/off main switch then buy an RCD version.
Similar Threads
  1. Silkcut1105
    35
    1,704
