extend-a-stay (1 Viewer)
des
128
south staffs
RV
5 years
i posted this on "facts" and think it worth repeating here.
"i had an extend-a-stay fitted when i bought my RV, but have never used it. The fitting for a propane bottle has a cut-off valve fitted. I recently discovered that this had developed a leak. Apparently this is a common problem, so if you have one, check it! I am removing mine, and using the BBQ point to feed back propane at low pressure, should i need to."
the leak occurs when disconnected from the bottle. there is a one-way valve incorporated, which weeps gas now.
des
scotjimland
2,324
10,060
A Woosh bang
Thanks for the warning, will keep an eye on mine..
damondunc
Aug 2, 2007
101
15
near Lincoln
The valve you are refering to is an excess flow device, in the event of a large gas leak developing whilst the extenda stay is connected it is supposed to shut off the flow from the bottle to the RV, if you are not using the extenda stay you are supposed to remove the pipe and fit the small brass blanking plug into the small connection on the T piece, that is why it's there. The excess flow device is not designed as a shut off valve when the bottle is not connected. (if the blanking plug is missing it should have been supplied with one from new and is attached to a small white plastic retainer that dangles from the T piece)
Dunc.
scotjimland
2,324
10,060
A Woosh bang
Dunc.
That makes sense Dunc, I have the cover on mine ..
Jim
des
des
128
south staffs
RV
5 years
thanks dunc
westcroft never supplied the blanking plug, so i just left my extension loose in the gas locker. so i learned the hard way.
des
