Exploring in the extreme (1 Viewer)
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Toying with the idea of going a little further off the beaten track, have a look and tell me if my big old Geist would bottom out or graze my solar panel.......
Extreme Road
Dec 6, 2011
11,467
25,057
South Wales
Coach built Adria
i dont know about the outside getting marked.... but... if i were with you the inside would certainly be [STRIKE]brown[/STRIKE], marked.:Blush::Blush::Eeek:
43,207
48,801
neither.....delivery trucks use that road. :thumb::roflmto:
11,793
13,948
Eastbourne East Sussex
Hymer low profile
Since 1972
Been on one just like that in French Alps. The road was a bit wider but the same sort of overhang and drop to the side. The overhang looked awfully low but the Rapido got under. There was a bit of a landslide part way down which was a bit worrying. It was probably on a bus route, they seem to go everywhere in France.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
no problem.....unwritten rule of the road, pull over for traffic coming uphill.
Looks uphill to me :ROFLMAO:
Actually, that is a written rule of the road in most of the world. In the UK Highway Code, it is section 155.
I was glad of it driving up a very narrow, congested, long and steep hill in Wales towing a large caravan with a very underpowered normally aspirated diesel minibus. 4400kg and 68bhp. If I hadn't forced everything coming downhill into various driveways and side turnings, it would have been at least a mile reversing until I could have got going again. I was flat out in first gear, and at one point, it really started slowing up...
voyagerstan
324
214
torquay sometimes
library bus (ford voyager
since1976
looks like karcorham hyw through pakistan planed on doing it to india afew years ago but had problems with iran visa so on hold for now . :winky: stan
Movinon
277
301
UK
Lots
Lost the waste pipe off the underside on one bad road, lost the injectors on another. I've seen a motorhome shake itself to bits on a bad road. Not mine fortunately. Ripping the tyres to shreds is routine. They overheat with flexing and come unstuck. You can tackle really bad roads so long as you have sufficient ground clearance but it's not pleasant. You need to find the right speed for your chassis, generally 60kph, and let about a third of the air out of your tyres to help the suspension. Unfortunately truck leaf suspension isn't designed for really bad roads so expect to slowly wreck your motorhome anyway. It is certainly one way to find out how well it was built.
