Exploding water taps (1 Viewer)
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
How can I stop any of the hot or cold taps from splattering everything within 5 feet:cry:
The tank can be full, bled out , the pump stays pressurized and does not click until the taps are on.
There seems to be 50% air in the system even though I can run the taps through, they seem to almost explode water everywhere even with the tap just on:Eeek:
I put a stew pot under one on Sunday and covered walls/floors ect:Angry:
Apr 25, 2012
794
826
Near Truro, Cornwall
Them bleeding taps
Hmmmm. We seem to have a similar problem in our Hymer. I always bleed the taps (all of them, including the shower) but after a day or so when I turn the bathroom sink tap on, it splutters and blasts water all over the place. So now I keep my trunks on all the time, though it can be a bit embarrassing in the local supermarket.
::bigsmile:
Jan 24, 2010
2,440
4,848
Adria Twin
possibly a leak or the pump starting to fail(water running backwards through it back into the tank), which in turn allows air into the system?
43,293
49,250
if the pump doesnt pulse unless a tap is opened it cant draw air into the pipes.....the pipes are pressurised and any leakage would be water going out...not air going in.
i suspect the pressure switch diaphragm spring has failed in so much as the cut off pressure has risen a lot and cutting out higher than normal.
J
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Could there be a split in the draw /supply pipe to the pump so as to draw in air ? then pressurize it:Eeek:
Bazzermc
54
40
Wiltshire
Autotrail Cheyenne
I'm a newbie
We have just used our motorhome for the first time.
I didn't notice any problem when I cleaned the system at home, but when we got on site every time we switched on a tap we had an "explosion". We made do and when I got home I started to look for an air leak in the feed to the pump......we didn't have the problem, but we don't have the water heater on, so is the air in the system created when we heat the water?
Anyone come across this?
Autotrail Cheyenne.
Easyliving
956
2,021
Norfolk
Since 2011
We have a similar problem with our Swift but we only get the 'explosions' when we first turn the tap on after switching on the pump, I assume this is due to air in the pipes.
I tend to have the kitchen tap only just switched on until only water is coming out.
Paul
