exhaust
Discussion in 'Peugeot' started by cookingfat, May 9, 2011.
  1. cookingfat
    cookingfat Read Only Funster
    Apr 25, 2010
    59
    5
    British West Hartlepool
    1998 boxer 2.5 tdi
    The final end piece of the exhaust has corroded through and dropped off.
    I'm having difficulty finding a exhaust fitter to fit new one, they say the motorhome is too large.
    Any suggestions in the Teesside area.
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi try the big boys like ATS and Kwick fit -they have big garage bays--I would go down the SS exhust route
    terry
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,337
    34,815
    You could try Discount Exhaust on Boundary Road in Middlesbrough (just off the A66 near Zetland car park) - 01642 228778. If they can't do it they will probably know who can.
    If it is just the very end would it be possible to fix it with a trim pipe? The end of ours corroded and I bought one of eBay like This One. To make sure it was properly attached and wouldn't drop off (which happened with a smaller one) I got an exhaust repair bandage kit and wrapped that round the joint after fitting it. It's lasted over 2 years so far.
    • Like Like x 1
  4. cookingfat
    Apr 25, 2010
    59
    5
    GJH I have a chome deflector on order, it should fit the bill.
    Many thanks
    Geoff
  5. GJH
    Aug 20, 2007
    27,337
    34,815
    Great. Hope it does the job.
    With our van it appeared that the original exhaust end was proud of the van side so drips had rotted it. Initially I cut the end off and put a shorter trim pipe on it - but that dropped off after a while, presumably because the screws holding the trim in position loosened.
    The second trim (as per link) is longer. It still uses one or two screws (can't remember how many) to hold it in position but the extra length means it goes further back up the original pipe. Having fitted it I wrapped an exhaust bandage round the joint to prevent the screws from loosening and that did the trick.
  6. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,647
    14,241
    North Lincolnshire
    I'd hate to be a poorly Kwik Fit Fitter........you cant get better! :Rofl1::Rofl1:
    • Like Like x 1
  7. GJH
    Aug 20, 2007
    27,337
    34,815
    Dunno about getting better - you get flamin' worse :Rofl1::Rofl1:
