Every MH needs this...
Discussion in 'Tech/Mech General' started by hilldweller, Dec 9, 2013.
  1. hilldweller
    Dec 5, 2008
    27,180
    26,154
    Macclesfield
    • Like Like x 4
  2. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    3,990
    6,483
    Roobarb land
    I have had a older version for a long time
    One of the best things I ever bought
  3. cranky
    cranky Funster
    Oct 29, 2012
    401
    459
    essex
    i have also had one for years. Just remember to double check circuits because just because it doesnt beep might not mean there is no voltage present, they are not always accurate.:thumb:
    • Like Like x 3
  4. hilldweller
    Dec 5, 2008
    27,180
    26,154
    Macclesfield
    A good point.
    What I had in mind is dark rainy night and the power goes off. Immediately you touch your hookup lead to see if it's inside or outside your MH.
    If the hookup is live you go searching inside otherwise head for the post.
    • Like Like x 3
  5. simbadog
    simbadog Funster
    Sep 12, 2012
    1,298
    2,186
    Wengen
    +1 :Smile:
  6. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,711
    Lost in La Mancha, Spain
    Just ordered one, thanks:Smile:
    • Like Like x 1
  7. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    Brilliant for checking for electricity where you expect there to be electricity. Just be aware, these devices pick up a range of voltages so it's quite possible to find an induced voltage in some metalwork where you dont expect it, which can be a bit misleading. We called them wet nail testers.
    • Like Like x 1
  8. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,527
    1,414
    West Midlands
    That specific item had sold out when I looked (such is the popularity of MHF!) but I was able to order what seems like a similar item. It's taken a couple of weeks to arrive but I was in no hurry.
    :help:
    Now, I'm no electrician. The slip of paper that came with it has (scant) instructions that haven't translated well from the Chinese. So I got the instructions off the sellers website as follows:
    Material Plastic, Metal
    Length: about 13cm
    Power Supply: Not need any power supply.
    It is great for use in confined areas with one hand.
    Pen shaped LCD Voltage Tester with a clip is portable for carry in your pocket.
    It is suitable for home, shop, garage, automotive, motorcycles, boats.
    Use:Distinguish between the LIVE WIRE and NEUTRAL WIRE; Detection electrical conductor whether live or dead.
    Voltage detection:
    Voltage detection range: AC/DC Voltage 12-250V.
    Indirect detection the LIVE WIRE,NEUTRAL WIRE and breakpoint of AC.
    Touch (DIRECT) button, metal tip contact the detected objects, the tester show five sections of voltage:12V, 36V, 55V, 110V and 220V.
    The final value is the measured voltage value
    (Did not reach 70% of the value of high-end, showing the low-end value).
    INDUCTANCE detection:
    1. Touch (INDUCTANCE) button, metal tip close to the detection of objects , if it show "high voltage symbol" said object with alternate current.
    2. Measurement disconnect the wires , Touch (INDUCTANCE) button, metal tip close to the outer layer of wire insulation, Disconnection phenomenon---"high voltage symbol" disappear at the breakpoint.
    Caution: Do not press two poles at the same time while detecting or else it will not display the exact result or the induction will be weakened.
    Can anyone help with a SIMPLE explanation of how it works?
    I would be grateful. :thumb:
    Wyn
  9. Tootles
    Tootles Funster
    Sep 14, 2013
    9,134
    32,583
    Lancaster
  10. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,816
    3,316
    Eastbourne East Sussex
    Just ordered 2, one for home and one for van. At £1.69 from China you can't go wrong.
  11. Popeye
    Popeye Funster
    Sep 5, 2011
    7,867
    17,676
    New Forest
    Also just ordered a handful, watched my kitchen fitter using one, impressed.........
    .........thanks Gren and you Brian
  12. hilldweller
    Dec 5, 2008
    27,180
    26,154
    Macclesfield
    Impossible to tell but you're not going to sue me at that price are you ?
    I couldn't even post it for that price.
  13. StitchUp
    StitchUp Funster
    Mar 12, 2012
    883
    953
    Bridgend, South Wales
    I always understood these only work with AC and NOT DC.
    As far as I'm aware, they work by detecting the magnetic flux produced by the alternating current.
  14. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    Had a problem with a ceiling light in the house and used on of these which indicated power to said light but NO light when switched on
    sparky said something about AC only and there was NO power to light so maybe good as a guide but that's about all I would say
  15. Allanm
    Allanm Funster
    Jun 30, 2013
    3,136
    4,279
    Cotes d'armor, France
    Black and Decker used to make a similar gadget, not pen shaped though, that would also detect wooden battens and hollows in a wall.
    This was in the '80's when I worked for BT.
    Allan
  16. Geordies
    Geordies Funster
    May 29, 2013
    953
    2,184
    Tyneside
    What your looking at is called a "voltstick".
    We are not allowed to use them to check for 240v AC.
    We MUST use these;
    http://www.ebay.co.uk/itm/Martindal...598?pt=LH_DefaultDomain_3&hash=item1c3abe2ea6
    You'll see that the tester comes with a proving unit. The proving unit produces 240v at low current. So what you do is, test the tester on the proving unit, looking for a live indication, then test the circuit under test, then test the tester again on the proving unit.
    The above makes sure that the tester is NOT faulty when testing a live circuit.
    The tester also has finger guards to ensure your fingers will not slip along the unit and make contact with live circuits.
    Hope that helps.
