European Breakdown Cover- Over 8m And 3.5t (1 Viewer)
John & Joan
1,425
774
Darlington
10 years this time
I insure via the CCC. Have done for years. The add on of Recovery By the RAC is worth every penny. They recovered a 7 + tonne Pusher R-V from Dover to the repairer in the Midlands, when a valve bent. And From Nr St Albans to Hampshire when the gear box failed.. They have arranged for a Welder to repair a Cracked Tow Bracket. Found me someone to investigate the loss of power In Spain, (had it failed they where ready to Uplift from La Manga to the UK) Low loadered me off the M25 when Both rear Tyres where wrecked by debris in the road!. They are courteous, and keep checking back to see if all is going to plan. I cannot fault them (yet).
As Far as I am aware you can (for cost) extend the cover to 180days (from the standard 90)
You have to be a CCC member though.
Pete
Comfort also use RAC Commercial and I can say they are excellent as you have found. We have had call to use them in Italy, Spain and the UK.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
They must have changed their terms since I last looked at it about 2 years ago. I recall there were size restrictions at that time.
Ezee
Not strictly true, there are certain conditions on height and weight, but they do not apply to motor homes. See the extract from their terms below.
Quote:
3 The vehicle can not go to design and furnishings for the carriage of persons not more than 9 seats (including
of the space for the driver) and
- A total width of 2.55 m,
- A total length of 10 m,
- A height of 3 metres and
- A total permissible weight of 3.5 tons do not exceed.
The same goes for the accompanying trailer. All dimensions are including cargo. The trailer may have no more than one axle. Axles with a distance of less than 1 metre apart, are considered an axle.
4. In addition, motorhomes are insured up to
- A height of 3.20 m, including cargo and
- A maximum total weight of 7.5 tonnes
2657
I think the highlighted clause 4 is still a size restriction, albeit increased for motorhomes.
kenvan
kent
coach built
As I said in my earlier post, I advise you all to check your policy. I have just re-read mine and Comfort insurance have a £500 recovery fee limit. They use RAC Europe and the recovery firms are sub contractors.
ken
Aug 18, 2011
12,138
18,003
derbys
AUTOSLEEPER SYMBOL
I can't believe how many times this subject comes up on the forum. We must be getting ready for a gassing or A frame discussion any time now..BUSBY:):):):):)
Mikey RV
4,901
24,230
Devon
Burstner Elegance I821G
Since 1977
I think the reason it comes up so often is because it's a bloody mine field out there when it comes to breakdown cover and think a lot of people think they are covered but I fact are not. So many different sizes, weights etc and the main thing not reading the small print.
Dec 20, 2010
1,648
2,966
birmingham
kon-tiki 669. mazda bongo
since2011
Hi, I have Fiat camper assit, will they fix any problems or do I reqire seperate insurance cover
