We are thinking of changing motorhomes is it worth waiting for the euro 6 and pay more or buy a euro 5+ cheaper?
Oh dear, certainly would not like anything like that rubbish to have to deal with !!!If the euro 6 comes with an adblue system I personally would avoid it like the plague if my experience with our trucks is anything to go by
My FIAT ducato euro 5+ has a built in cleaning system which is activated by a sensor, it does not rely on running at a certain temperature. If it decides to clean itself there is a message light on the dashboard.Whether you choose a five or six they run at a higher temperature to clean the dpf, which means you have to drive it at 3 to 3.5 thousand rmp for at least half an hour regularly to clean the system otherwise the yellow light will come on. If you do a lot of motorway driving at 65mph that will help. Personally I have a euro 4, less hassle all round. I certainly would not buy a Euro 6 until they have been tried and tested other than on a test bed in the lab! Ad blue only be present in HGVS , another running cost to be absorbed. My Euro 5 truck uses 25litres per week at 70p per litre.
I wonder if the new Fiat Euro 6 engines use integrated exhaust manifolds in the cylinder head? This is a relatively new idea which promises less problems with blocked catalytic converters as the cat can be fitted closer to the head and this means the exhaust gas enters it at a higher temperature.Fiat Professional has announced that it will just be using EGR (Exhaust Gas Recirculation) technology to achieve the Euro-6 emission standard, which is due in September 2016. So far, the Italian company is the only manufacturer not to use SCR (selective catalytic reduction), and will therefore not require the addition of Adblue solution.
Instead, Fiat is using an enhanced version of EGR, called Low Pressure Exhaust Gas Recirculation (LPEGR), which draws exhaust gases downstream of the turbocharger and returns them upstream of the compressor to reduce emissions.
Using LPEGR requires fewer components and no Adblue tank, which means the payloads of the Euro-6 Fiat Ducato aren’t affected as much as its competitors.
Go FIAT .......no blue pi $$Fiat Professional has announced that it will just be using EGR (Exhaust Gas Recirculation) technology to achieve the Euro-6 emission standard, which is due in September 2016. So far, the Italian company is the only manufacturer not to use SCR (selective catalytic reduction), and will therefore not require the addition of Adblue solution.
Who is correct? I could not find any info on the FIAT website.Further to my earlier post, Fiat have adopted the Adblue system on their Euro 6 engines.
I've recently collected a new Burstner that was one of the last units to be fitted with the Euro 5+ engines and discovered it has the latest styling tweaks, Manual for Euro 6 models and includes the blanked off fill point for Adblue, which is located below the fuel filler.
Only if you dont like parking in cities and driving through ever larger environmental zones.....Think i will stick with my not EURO anything,,,it will make life easier,,BUSBY.
