Environmental Warning Light Boxer X/250
Discussion in 'Motorhome Chat' started by cater_racer, Jun 18, 2010.
  1. cater_racer
    cater_racer Read Only Funster
    Oct 15, 2008
    46
    Chester
    My engine environment warning light came on my Autocruise Augusta with only 8,000 miles on the clock. Had the oil changed and the air-filter etc, but it's stubbornly stayed on.
    I've put Forte diesel cleaner in the last 3 tankfuls, but to no avail.
    Engine performance has been unaffected, and fuel consumption is good.
    I'm assunming it's due soot or similar build up in the silencer system.
    What's the best resolution? (disconnect it?)
    Cater
  2. reeventu
    reeventu Read Only Funster
    Jan 19, 2010
    15
    take it to the chassis dealer , Fiat or whoever.
    I had this problem and it was something to do with emission controls, cannot remember but it was sorted under warranty
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,680
    5,837
    Mansfield,Notts
    It needs a diagnostic check as a matter of urgency
    your vehicle may use the exhaust enviroment emission fluid system and the light may indicate low fluid level, have you not checked hand book:Doh:
    Ignoring it and leting it run dry will block the cat and chambers, the following repair bill will make what you have spent so far look like small change:Eeek:
    Geo
  4. cater_racer
    Oct 15, 2008
    46
    Chester
    I wish it was that simple, there are no local peuguot dealers who will take the vehicle in, they refused even the warranty service due to the weight being iver 4 tonnes. Elf & Safety won't let them change the oil.
    There is no special fluid and the handbook say's "Take it to your dealer".
    The French dealer, couldn't do it when I took it in, fully booked up, but shrugged his shoulders and said, don't worry about it.
    That was in Barritz I drove it home 1000 miles since then. But had a full service in my local HGV place, and he said, "dunno", seems to go alright, and the particulates are within spec.
  5. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    It really does need a diagnostic check. If its in warranty there should be no charge, but there will be if a serious fault developes and you have ignored the warning.
    There must be a peogeot dealer somewhere that will take it! The one in Shrewsbury would, as would the one in Stoke, or Birmingham (not sure where you are).
    This light is a bit of a catch all, there are all sorts of faults that can cause it to come on. I have had it on twice (two different vans). the first was caused by a failing butterfly valve in the induction system, which also caused loss of power. The second reported an intermittenet fan problem - no obvious symptoms. But it was actually a fault in the software of the EMS, fixed by the dealer updating the software.
