Engine will not switch over to LPG (1 Viewer)
electricscott
203
66
Buckden Marina
3 year
ocassional when going up a steep hill a warning buzzer indicates an empty LPG tank, this normally corrects itself and I can switch back to running on gas. However after going up severe steep hills the controller is now perminately showing an empty LPG tank making it impossible to switch over from petrol to LPG. I know I have a full tank. Any suggestions to the cause?
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Years ago I had this problem on my landrover and it turned out I needed new tank valves.
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
The system will have a pressure sensor to tell the controller that there is sufficient pressure to run the system.
Sounds like you have a sensor that has failed or more likely one of the wires has corroded and broken off it.
The sensor is usually on the vapouriser.
Peter
Apr 29, 2012
312
287
Holmfirth
1990 Gulfstream RV
30yrs
Could be the sensor as said or could be the solenoid valve that controls the switch over,has gone
43,289
49,223
You need a professional LPG fitter to check it over.
I only get switched back to petrol when i have ran out of gas.....hills have no effect, as they shouldnt.
E
electricscott
203
66
Buckden Marina
3 year
Thanks for the advice I will check the the wire on the vaporiser and seek a professional LPG engineer when we get back to England
