engine turning but not firing
Discussion in 'Motorhome Chat' started by swiftcalled1ggy, Nov 16, 2011.
  1. swiftcalled1ggy
    swiftcalled1ggy Read Only Funster
    Nov 16, 2011
    3
    sw scoland
    Hi folks,can anyone offer any advice? I started my Swift Ducato 570 1.9td after a couple of weeks sitting idle on the drive,anyway, it started fine and i moved it a few feet letting it tick over, i noticed the fuel gauge had not moved,after a few more minutes i switched the ignition off. When i went to re-start ( 5 minuts later)the engine ,after the heater plug light went out it would only turn over but not fire up:cry:I knew there was fuel in it but put 5 gallon in just incase someone nicked the fuel but this didn't solve the problem,anyone got any advice cos I'm at my wit's end :Doh:
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,335
    5,339
    East Sussex 01-580-881288
    Could be that the fuel cut off solenoid has now stuck in the off postion, try turning the ignition on and off a few times.
    Peter
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    if some scroat did syphon it dry you may need to bleed the system.
    i think the 1.9 has a mechanical pump so if the fuel filter housing has a button on top press the button until it cant be pressed any more.
    try starting....
    if it still wont you may need to bleed the injectors.
    do this by 'cracking' (loosen) the injector feed pipes, one at a time, while cranking until fuel appears then tighten.
    otherwise it could be the fuel cutoff seloniod or fuse is faulty.
  4. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,153
    13,979
    Heavan
    what age is your van? does it have a factory fitted immobiliser? they can be a bummer for not deactivating, are any lights still on the dash?
    rule this out first as it's a common problem.
  5. swiftcalled1ggy
    Nov 16, 2011
    3
    sw scoland
    got her going
    Thanks for the advise,turned out to be a blown fuse:Doh:
    • Like Like x 1
  6. hilldweller
    Dec 5, 2008
    27,204
    26,193
    Macclesfield
    Fuses should never blow, so find out why before you get stranded.
  7. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,881
    Full timing in the van
    IF they never blow why do they have them :Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
  8. hilldweller
    Dec 5, 2008
    27,204
    26,193
    Macclesfield
    I didn't say they never blow, I said they should never blow. They blow only under a fault condition mainly to prevent a fire when the cable gets hot.
    The fuse is usually chosen to suit the cable size though it can be lower if a convenient cable size is capable of a lot more current than the gadget requires. So a 10A cigarette lighter socket could be wired in 20A cable but the socket would melt above 10A and therefore a 10A fuse will be used.
    If you don't find the fault it remains there just waiting to happen again.
  9. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,881
    well thats me been told:Laughing:
  10. Popeye
    Popeye Funster
    Sep 5, 2011
    7,871
    17,700
    New Forest
    Give Him a slap
    • Like Like x 1
  11. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,881
    Got to let him off is wife gives him a noth slaps :Rofl1::Rofl1::Rofl1:
  12. hilldweller
    Dec 5, 2008
    27,204
    26,193
    Macclesfield
    Edukashun, you can't beat it.
