Engine problems
Discussion in 'Motorhome Chat' started by freelanderuk, Jan 6, 2011.
  1. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    i have just had to replace the expansion tank on the engine due to one of the inlet pipes cracking in the cold , on removal i found that the rear pipe had been chaffing on a bracket and if left i would have lost all the cooling water , all replaced at a cost of £63 including antifreeze, started the engine up and there was a horrible noise as though a bearing had gone.
    the van was booked for its service so i took it to them and told them about the noise, they found the problem while doing the service , it appears that part of the timing belt cover had cracked and and a piece of it was caught on the alternator belt causing the noise and cutting threw the belt, they rectified the problem and replaced the belt FOC ,
    apart from the chafing pipe the other problems have happened within this cold spell
    my engine is the 2.8jtd and if you wish to check your rear water pipe its located at the back of the expansion tank with a bracket right next to it
  2. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    Why did the garage replace the belt FOC ? They're not cheap. Did they replace the timing belt cover FOC as well? Just curious.
Similar Threads
  1. jemhorn
    17
    737
  2. critch
    29
    1,975
  3. robrace
    4
    359
  4. Ovalball
    19
    840
  5. robrace
    533
