5w/20 or 5w/30 i believe......havent had to do mine yet as i havent had it long..:thumb: takes around 7ltr and the filter is a Fram PH2 .....common enough here in the uk and used on many truck engines.
have a look over on motorhomefuns sister site RVOC for all things RV.
the triton engine MUST run on the correct oil....
a new engine, on a pallet, is around £3000 so you dont want to put the wrong stuff in.
