Engine Oil
Discussion in 'Motorhome Chat' started by jemhorn, Jul 28, 2016.
  1. jemhorn
    jemhorn Funster
    Nov 13, 2013
    383
    332
    Bideford, Devon
    Just want to get a bottle of top oil should I need it for my 2014 Fiat Ducato 3Ltr 180bhp engine. Suggestions?
  2. martin1485
    martin1485 Funster
    Jan 26, 2010
    443
    666
    Conwy, North Wales
    • Like Like x 1
    • Thanks Thanks x 1
    • Informative Informative x 1
  3. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,601
    1,662
    Stretford
    Will tell you exact specification in the Fiat manual, it's important to use the oil specified by the manufacture
    Could ring a fiat professional dealer and give your Reg from which they can confirm the specc
    My van came with a small top up bottle from new, have you checked the tool kit that came with van
    • Like Like x 2
  4. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,752
    11,954
    Plympton, Devon
    Done 24,000 miles in ours since new in three years, same engine and not had to top up - although I do change the oil every year.
    • Like Like x 1
  5. jemhorn
    jemhorn Funster
    Nov 13, 2013
    383
    332
    Bideford, Devon
    Just heard back from Fiat dealer and he suggests 5W/30 Fully sysnthetic, low ash oil. They stock Selenia WR PE which will match the one used at the factory. Apparently the Low Ash element is critical for vehicles running the newer engines with anti-pollution filters etc.
  6. ivorantony
    ivorantony Funster
    Jan 22, 2013
    504
    536
    London SE
    that's to stop your DPF from clogging up early, always use the best quality oil you can get it will repay it self in the long run,
  7. taffybloke
    taffybloke Funster
    Dec 6, 2011
    325
    216
    West Wales
  8. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,553
    2,561
    Tunbridge Wells
    Bought a litre in the auction at the Thetford meet. Not needed it yet to top up.
  9. Badknee
    Badknee Funster
    Aug 25, 2014
    3,732
    16,410
    notloB
    For my 2.8 HDI it states do not use 5w40 but 10w40 only??
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    Excellent value...enough for a couple of oil changes.
    5ltrs of this will normally retail at around £29
    direct from an official merc dealer.
    5/30 low ash
    I use this in my merc engined chrysler.
    http://m.ebay.co.uk/itm/181786821177
  11. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,568
    3,375
    Telford, Shropshire
    The 2.8 is a relatively old engine now and 10W40 semi synthetic is the correct oil for it. The 3.0 litre engine is a totally different bucket of bolts and 5W30 fully synth or 5W40 fully synth is the correct oil for it, low ash (sometimes called low SAPS) is a must for any engine running with a DPF which yours doesn't have.
    D.
    • Informative Informative x 2
    • Thanks Thanks x 1
  12. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    774
    469
    Cornwall/France/Spain
    Do these 'modern' engines ever have to be topped up? My basic old 2.5TD never, never needs to be topped up and the same goes for my 1.6HDI engine car. Am I just extremely lucky?
  13. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,553
    2,561
    Tunbridge Wells
    My new Hymer with 3l engine has done 7,000 miles since I bought it last November and I have not had to put a drop in up to now.
  14. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,617
    4,034
    Newbury , West Berkshire
    Does it matter much if I put 5/30 or 10/40 oil in my 2.8 hdi engine. ??
  15. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    473
    808
    Derbyshire
    Yes it does. 5/30 is too thin for it. Always use the correct grade to minimise wear and oil usage.
    • Thanks Thanks x 1
  16. dave newell lvs
    Oct 31, 2008
    2,568
    3,375
    Telford, Shropshire
    2.8 HDI is the same as the Fiat 2.8 JTD so as above 10W40 semi synthetic is the correct oil for it.
    D.
    • Thanks Thanks x 1
  17. campa cola
    campa cola Funster
    Oct 5, 2012
    2,907
    5,796
    Weegeland
    My modern engine has done 9000 without a top up and my (non classic) exhaust did not fall off either ;)
  18. Flamenca
    Jun 21, 2013
    774
    469
    We could open a whole new can of worms if we start talking about 'Classic' Hymer exhausts :D
  19. Time4T
    Time4T Funster
    Jul 31, 2016
    27
    24
    Fife
    I don't & never will own a vehicle with a DPF, When they were first fitted, they were lauded as the next step in zero emissions, but when a proper scientific study was carried out, they found that the DPF actually increased the amount of harmful particles, that were found to be floating in a cities air.
    The reason is because the DPF traps the larger particles, thus the smaller sub microscopic particles were still getting through, these are the ones that float & are ingested by anyone breathing city air.
    These micro particles used to cling to the larger ones & fall to the ground but the DPF now prevents this from happening!!!
    The catalyser however is a very good devise that does what it's supposed to!
    By the way I only ever use 5w/50 full synthetic motorsports racing oil in all my vehicles.
    Phill
    • Like Like x 1
