Do you think in years to come our kids and grand kids will say do you remember the old days ? We just used to plug the lap top in, buy a new ecu and it was all fixed .
Didn't get that trouble with the Morris Minor!
BRAKE FAILURE !! STOP VEHICLE SAFELY AND SEEK ASSISTANCE
I drove into the little garage I had just passed-
Mike
if its an electronic fault there will be a code stored in the ECU.
You need someone with an OBD2 code reader or a dealer to diagnose the problem.
I believe the immobiliser is part of the ECU and if faulty a replacement ECU may be needed.
not cheap.....i think around £800 to £1000
There are two problems neither of which has anything to do with progress. The first is the unwillingness of formerly keen DiY and professional motor engineers to involve themselves in electronic management and the second is the repair and pricing policies of the motor trade. There isn't one "black box" or sensor on a modern vehicle that costs more than £15 to manufacture - in fact most sensors will cost under £5 to make. The motor trade must be laughing all the way to the bank when customers appear to be willing to pay £50+ per hour labour charges for the attention of "technicians" who can do little more than read a screen & change the over-priced components suggested. Even before EFI the normal diagnostic method for car electrical parts was to substitute with new - with the customer paying for each item replaced until the fault went away. Nothing has changed except there's a new way of fleecing customers. As garage visits reduce because vehicles are more reliable & service intervals are extended there's a need to maintain income so they charge more for the parts. :soaobox:
I wouldn't admit to working for Bitish Leyland mate!What is this a Luddite convention?
1977 I started my apprenticeship in a British Leyland main dealer.
1978 British Leyland had some QC issues with Marina gearboxes, result was we replaced so many we could do one in 22 minutes between two of us, timed from workshop door inwards to workshop door outwards: no sensors involved.
1979 BL had QC issues with "A" series engines, result we rebuilt so many engines our workshop looked like an engine build shop not a general garage, in one week alone I remember having twelve different cars with engines stripped down and sent away for rebore/new pistons etc. No sensors involved and these engines were ALL in BRAND NEW VEHICLES with less than 3000 miles each! Carburettors needed constant fettling to maintain some semblance of correct AFR, points needed checking and adjusting at 3000 mile intervals, valve clearances needed adjusting at 6000 miles , oil and filter service at 6000 miles and full service at 12000. Diesel engined small vehicles were a rarity and those that were about were slow, noisy, dirty, smelly things with 2.5 litres giving a breathtaking 50BHP and needed a calendar to time the zero to sixty MPH. Turbos were for big trucks and earth movers, not even high performance cars had turbos.
Fast forward 30 plus years and we now have diesel engines in almost everything and they're superb by comparison with the petrol engines we used to have and why? Because they're electronically managed which means a heavy reliance on electronnic sensors. The upside of that reliance on electronics is quiet, refined, economical and powerful engines in both petrol and diesel formats and turbos with everything. Overall they are far more reliable than the rubbish we had for the last hundred years.
D.
You do seem to be tarring all with the same brush, see my previous post.
I note you worked for BT? Bet they never ripped off customers??
Over the last 60 years, I have owned, driven or been responsible for 100`s of vehicles, from motorcycles ,through cars, vans, trucks, P S Vehicles, campervans, motorhomes etc. I have learned that maintenance and respect for the mechanicals and basic knowledge of what happens under the bonnet are the keys to trouble free motoring. Over more than 1,000,000 miles, I have suffered very few roadside breakdowns. When these have occurred, I have usually been able to sort them out ,and only had to refer to breakdown services on very rare occasions.
Over the last few years, however, with the proliferation of so called engine management systems. I have suffered several roadside failures, necessitating reliance on rescue services and the consequent inconvenience associated with breakdowns.
In each case it has not been a mechanical failure as such, but a computer failure in a sensor which has shut the system down. Each repair has been ridiculously expensive needing the replacement of a sensor, to say that, that which was not faulty is no longer faulty, if you get my drift.
[HI]My question is this:- Should progress inevitably be regressive as is the case with engine management systems. Do we really need them?[/HI]
But the problem here is you are judging the entire motor industry on your own limited experiences. Many people have modern vehicles that never give them trouble.
D.
We could continue to argue the point. My own limited experience tells me that sensors are causing a problem that I don`t have. Several vehicle technicians are telling me the same thing. Probably your own limited experience has not encountered these same problems. All I am saying is why do we need these unnecessary technical gizmos when we have managed quite well up to now, when progress is causing so much hassle or is it just another way to line the pockets of the motor trade repair industry. Present company excepted of course
I am working on a Renault Master 2002 van doing a camper conversion I am dreading taking the thing abroad when finished. I just know we will get electrical problems I probably cant fix, this isn't progress is it?
It's not just vehicles either. In industry, machines that cost tens of thousands of pounds per hour stand idle because sensors "think" there is a fault.
There are two problems neither of which has anything to do with progress. The first is the unwillingness of formerly keen DiY and professional motor engineers to involve themselves in[HI] electronic management[/HI] and the second is the repair and pricing policies of the motor trade. There isn't one "black box" or sensor on a modern vehicle that costs more than £15 to manufacture - in fact most sensors will cost under £5 to make. The motor trade must be laughing all the way to the bank when customers appear to be willing to pay £50+ per hour labour charges for the attention of "technicians" who can do little more than read a screen & change the over-priced components suggested. Even before EFI the normal diagnostic method for car electrical parts was to substitute with new - with the customer paying for each item replaced until the fault went away. Nothing has changed except there's a new way of fleecing customers. As garage visits reduce because vehicles are more reliable & service intervals are extended there's a need to maintain income so they charge more for the parts. :soaobox:
D.
Mine was much the same except I started in 1968, yes they are longer lasting etc. etc.( when did anyone last have a "decoke & grind the valves" or " points & condenser") but as an RAC contractor, I used to drive round in a breakdown truck laden with parts & it was rare that a vehicle could not be repaired on the spot.
It's not just vehicles either. In industry, machines that cost tens of thousands of pounds per hour stand idle because sensors [HI]"think" [/HI]there is a fault.
The longevity of modern engines is because of the vastly superior oils available, and the demise of British Leyland, not electronics.
[HI]
[/HI]
Hello DBK.
All I am asking is why?
In this day and age when recycling is thrust upon us, am I forced into a position that failure of a sensing component is tantamount to huge expenditure on something that isn`t actually needed?
I agree that engines have become much more efficient, and that white van technology is what is regarded to be the norm. But does it make sense that, for instance a failing sensor can cause a complete engine shut down, which has happened to me twice now, fortunately not at 70 mph on the motorway, but never at a convenient time, (if such an unnecessary breakdown could be described as a convenient time)?
Do ,for example we all instantly know what all the dash warning symbols mean when a sensor plays silly b**ggers or because so many false warnings manifest, do we assume that they are calling wolf and ignore them till one day a proper fault is recorded? Even a poor earth connection can cause Blackpool illuminations on the dash.
Progress?
I blame it on the money men. In any industry if you can take most of the labour element out of the equation you can control the cost better. If it wasn't for quantity surveyors wanting a screw that could be handled by a machine we wouldn't be lumbered with Philips screws.
