Engine management prob on 2.8jtd ducato
Discussion in 'Tech/Mech General' started by keith1950, Sep 9, 2011.
  1. keith1950
    keith1950 Funster
    May 2, 2011
    3
    derbyshire
    whilst driving i noticed my engine management light had come on also speedo stopped working and enging gone into limphome mode.
    We pulled over stopped engine then restarted noticed that the glow plug light was flashing for about 30 times then went out.
    has anyone got any ideas as to what the problem could be the book only refures to engine management light faults being injectors,fuel pump or vapor heater:Cool:
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,737
    5,967
    Mansfield,Notts
    At the very least your going to need a scan looking for fault codes,
    If it only happend the once and the lights are now behaving normally,there maybe no codes present
    The ecu likes to see certain fault scenerios twice or three times befor it logs it in
    If the Engine fault light is on all the time then the code will normlly be locked in and requires at least clearing
    Its a good idea to purchase a cheapo ebay scanner and clear your own faults once or twice to prove it has an actual fault before remedial action is carried out
    I have said many times on here getting the code is extreamly easy, what you do with them is where the hard work starts, never be tempted for example to run out and buy a lamda sensor because the code says lamda out of range there are multiple reasons why any one code is logged and those reasons need to be found and eliminated, the lamda may in deed be damaged but what caused it? it will damage your new one too
    The above is an example to try and explain diagnosis and codes, not what your personal problem may be:thumb:
    Geo
