Engine Light (1 Viewer)
Jan 18, 2010
538
138
Airdrie Scotland
6 years and 20 years as a tugger
Yes its that time of year when the Temp Drops The Fiat Cash Machine Light goes on (Engine Light) same last year trip to Fiat Dealer some sensor and £200.00 LIGHTER IN THE POCKET Please is there any way you can turn this light of and reset or is it another trip to the Fiat Dealer
Bill
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
The piece of On Board Diognostics equipment mentioned above will enable you to turn the light off. It obviousley allows you to carry out your own Onbord Diognostics check and you are certain to be presented with a range of stats which can be converted into Engine Management Problems.
These problems may be just a matter of your own misinterpeatation. Before you get yourself messing with stuff that you may not understand, can you not find a garage who will happily turn the light off for you. It doesnt have to be a Fiat dealer.
Jim
:Smile:
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
it depends what year the fiat is , some are OBD1 and some are OBD2 , mine is a 2002 reg fiat and OBD1, look on the fiat forum for the fiat scan software or visit here Link Removed , to find out if your are 1 or 2 lift the bonnet and have a look down the right hand side of the inner wing , you will find some connector blocks ,obd1 connector is 3pin and you will have to get this lead from hong kong , obd2 is 16 pin i think and there are plenty on ebay
they now have the obd1 to obd2 connector lead in the uk Link Removed
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
The 'States don't grt it all right
BUT--------you can got into a car accessoyy shop and they will read your code FOR FREE---------some will put the light out ----but they will all tell you what the light is saying.
We bought a high spec code reader for $100 :thumb: ------the cost of getting our code read once !!!!!!!! in this country:Eeek:
Nigel & Pamala
niggle
Banned - Rule 1
Banned
Aug 5, 2010
804
601
SOUTH AND FRANCE
A CLASS
all leads and equptment from,, aandetraiding.com they aer in slough and have supplyed me,, good value and cheap with garantee ,,, no sending it back to h/k ::bigsmile:::bigsmile:
Oct 15, 2007
1,621
280
Five Roads Alyth
A class RV
since 2005
Nigel & Pamala
I heard about this and wouldn't it be nice if we had such a service?
Also, as I understand, the Yanks legislated that from 1996 all vehicles had to be ODB2 compliant to stop the need for different readers/software for every manufacturer, again wouldn't it be nice if we had the same common sence:Doh:
I did buy a ODB2 reader when we got the first Jeep, great piece of kit and rather than just giveing the code there is a discription with it, mind you the only actual fault code so far was for a faulty gearbox speed sensor, and a bit vauge, but a quick google and £30 later all was well, I can imagine what the stealership would have charged to diagnos and repair, bearing in mind having sorted myself the sensor took 2 minutes to change and I didn't even need to jack the Jeep up!
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
We have a auto electrician that comes to your house and charges 20 quid to plug in his lappy and reset / diagnoses any thing that is wrong- if he is at the local garage that uses his services it is only a tenner :thumb:
terry
B
Jan 18, 2010
538
138
Airdrie Scotland
terry
I have arranged for a local Auto Spark to come to my door as you said £20.00 quid for a full check
