Engine Coolant Drain Down for winterisation
Discussion in 'Motorhome Chat' started by madbluemad, Oct 4, 2008.
  1. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Hi Folks
    I am now planning to winterise my mh as it will not be used again until next year. Unfortunately work demands that I cant get off to sunny climes for the winter.:cry:
    I am in two minds as to whether or not to drain down my engine coolant. It is currently filled with 50% Coolant and 50% distilled water.
    This is good for -36°C.
    I dont believe that I will have a problem if I leave it alone until its service etc next March.
    What do other folks do or think.
    Jim
    :Smile:
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,852
    6,108
    Mansfield,Notts
    Take it from the horses mouth as it were
    Leave well alone, a drained system is open to corrosion :Eeek:
    Geo
  3. Bulletguy
    Bulletguy Read Only Funster
    Feb 7, 2008
    2,051
    6
    Cheshire/Staffs
    The only water you should be thinking of draining off completely is any fresh/dirty water tanks you have fitted......not a radiator! Thats why it has coolant in!!
  4. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    I go along with that.:thumb:
    Antifreeze has anticorrosive additives in it.
    The system will corrode badly if drained and the water pump will seize.With a 50% mix of water to antifreeze you'll be well protected.
    Steve.
  5. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Thanks guys. Thats one decision made.
    Jim
    :thumb:
  6. Bulletguy
    Feb 7, 2008
    2,051
    6
    Cheshire/Staffs
    Its also a good idea to turn the engine once a week and let it run up to normal temp.
    Also, if your mh is standing outside don't stick one of those all over covers on it....they come with a built in body rot guarantee! Likewise, ensure the underbody sealant is in good nick and kept well aired. If you have a large enough garage then you won't need to worry too much about this.
    'Winterised' motorhomes suffer more from lack of use than if they were used daily.
  7. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Its to big for a garage, we thought about storage but I like to be able to keep a constant eye on it, plus do a bit of fiddling about.
    We were thinking about a cover in fact I have been looking on the web for one.
    Thats another decision made
    Jim
    :thumb:
  8. Bulletguy
    Feb 7, 2008
    2,051
    6
    Cheshire/Staffs
    Hi Jim
    Covering up plastic is fine......covering metal is quite another thing altogether. Any metal panels dont get chance to air so damp is constant and it isn't long before a scratch turn to rust and the rust quickly develops into rot.
    The underside of any vehicle left to stand through the winter months also needs care and attention. Can't beat a good oil spray but as H&S have outlawed that now it's difficult to find any garage prepared to do it (there are still a few around!).
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    i bought a full cover last winter...what a waste of time and money.
    took me and my bro a good half hour to fit.:Angry:
    any vaguely sharp edges work their way through.....this included the corners of the aircon unit which you could headbut all day and only get headache...wing-mirrors the same.....even the mid height tie-down straps started to wear through where they rubbed the cover lower down.
    wont bother this year.
    maybe see if it fits over the caravan to keep the tree sap and bird sh*t off til it gets sold.:Blush:
  10. camcondor
    camcondor Read Only Funster
    Jul 27, 2007
    1,044
    478
    East Midlands
    Fiamma make covers which protect the roof from the green/black grunge that seems to develop so easily over the winter. They only cover the roof and a little over the sides, and are made from a breathable fabric, so should not be a problem. They are a one-size-fits-all variety, suitable for most vans.
    Towsure do full body covers, as do Protech (made to order for each van)and these are also of loose, breathable fabric, but as with all car covers, should be regularly taken off and not left in situ for many months at a time.
    Each of these has their merits, but need to be carefully used and not just left on the van for long periods without removing them for a while.
  11. warwick
    warwick Read Only Funster
    Sep 16, 2008
    113
    Winterisation
    Its far better to take van out fairly frequently than leave it stood, so that all lubricants get "splashed" around, suspension etc benefits. If your van has air con that needs running on a regular basis, some manufacturers recommend fortnightly others monthly.
    I tried a breathable cover on a caravan once but found the dampness within the van was sustantially higher, mould spots appeared here and there, and that despite frequent opening of van door to air.
  12. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Its all a question of balance.
    I would love to keep my rv on the road throughout the winter however it would only be occasional weekends due to the weather and I cant justify the expense in tax etc for a weekend or so.
    I reckon that as long as I keep a good eye on it, run the engine on a regular basis, wash it, wax it, inspect it, I will be OK.
    Jim
    :thumb:
