Engine Battery
Discussion in 'Hobby' started by Pezza, Feb 12, 2012.
  1. Pezza
    Pezza
    Jul 30, 2011
    53
    7
    Coventry
    On my hobby 750 should the engine battery charge up when the van is parked up and on EHU?
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,861
    6,113
    Mansfield,Notts
    Hi Pezza
    In reality the answer to your question changes like the weather
    For every 750 owner that said his does, there will be one that said his don't
    Your Motor Home is either configured to do it automatically or via a switch on a control board or not at all
    It seems these options can apply to almost any make or model, can you see a switch on your board with a pic of a van cab, or a switch that's labelled habitation batt that can be rocked to another position ie eng batt
    As said many times on here a multi-meter will give you the true picture
    Geo
  3. Pezza
    Pezza
    Jul 30, 2011
    53
    7
    Coventry
    Hi Geo
    Thanks for the info. There is no switch at all so as I suspected it only charges the habitation batteries. I have installed a cetek cigarette type socket direct to the battery and can now leave th cetek charger permanently plugged in vis the 240v in the habitation area.
    Ideally if I had the time to use it more then the battery wouldn't go flat - but too much work commitments at the moment!
    As you confirmed, each unit is different.
    thanks for the help
    Pezza
Similar Threads
  1. Douglas1
    25
    682
