Engine Battery Discharge Advice Please
Discussion in 'The Beginner' started by IanF, Oct 10, 2015.
  1. IanF
    IanF Funster
    May 7, 2013
    2,228
    652
    Redcar- N.Yorkshire
    Our battery charges to 13V + after running the engine for 30 minutes approx.
    The battery is a YUASA 95 amph.
    After 3 days of inactivity the voltage drops to 11.5 or less and after 4 days it has dropped to 11V and the MH requires a jump start.
    Can I ask is the voltage drop irrefutable evidence that the battery is knackered?
    I ask this question because I'm taking it back to the dealer who wants to run a 24 hour test on the battery before agreeing (hopefully) to renew it and I don't want to be fobbed off by some inappropriate statement!
    Thanks again in anticipation
    Ian
  2. berni109
    berni109 Funster
    Sep 10, 2012
    344
    295
    worcester
    Take the battery out of the vehicle and charge it with a 4 stage charger for 24 hrs.
    Measure the voltage when fully charged (totally disconnected) and then every 2 hrs.
    If the voltage continues to fall over 24 hrs then its fubar‘ed.
    • Like it Like it x 2
  3. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,516
    3,730
    Lost in La Mancha, Spain
    As you have run it / charged it via your engine and then left it for 3 days and it has dropped to 11.5 the battery is U/S period. It needs replaced now. I would also recommend a battery master which Jim sells here on the forum, which will therefore give you no further problems with the battery after it's replaced.
    • Like it Like it x 1
  4. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,959
    3,939
    Corby, Northants
    The 13V reading confirms your alternator is working as it should and charging your battery. The battery voltage drop over 3 days is an indication of A, a drain being placed on the battery which would need to be investigated further. (just replacing the battery with a new one would soon result in the same problem. B, Make sure your habitation 12V services are being fed from your leisure batteries and not your cab battery. C, The battery no longer capable of holding it's charge. This could be for a number of reasons, a sulfated battery etc.
    Let the dealer do his stuff and wait till he responds before doing anything else. It may be as simple as need a replacement battery due to age. They don't last forever.
  5. IanF
    IanF Funster
    May 7, 2013
    2,228
    652
    Redcar- N.Yorkshire
    Thanks I should have said I already have one of Jim's battery master fitted along with 2 solar panels which maintain my leisure batteries upwards of 13.7 V
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,265
    17,931
    YO11 2BD
    If in doubt just replace it.
    If, as you say, it has a BM fitted and solar your battery is cabbaged.
    An engine battery will cost around £60 at a guess.
  7. IanF
    IanF Funster
    May 7, 2013
    2,228
    652
    Redcar- N.Yorkshire
    Thanks Pappajohn but I do hope to get Marquis to replace it for me as I don't think you can say it's fit for purpose if you have a MH which can't motor without a jump start every 4 days or so
  8. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,299
    3,104
    Kendal, Cumbria
    With engine running the voltage at the starter battery terminals should be over 14 volts (around 14.2 to 14.5). Any less than 14v and the battery is not being charged. Have the alternator checked and the battery fully charged off the vehicle then try again.
  9. IanF
    IanF Funster
    May 7, 2013
    2,228
    652
    Redcar- N.Yorkshire
    Thanks for that advice -I've never actually checked the voltage with the engine running. I've checked it within minutes of stopping and get results in the upper 13 Vs
    Ian
  10. Charlie
    Charlie Funster
    May 16, 2015
    2,609
    3,091
    Have you done a drain test ? Often called a parasitic draw ?
    If you have a simple voltage meter it's not hard to do.
    If it's of interest I will find a YouTube link to a video which will explain it better than I can .
    If your battery is over 13 after a drive I would say your alternator is working fine. If it drops after that it's likely you have a draw on it.
  11. Charlie
    Charlie Funster
    May 16, 2015
    2,609
    3,091
    Look at the video below. It's long but for those with vehicles like ours it could be of much benefit .
  12. The Silvers
    The Silvers Funster
    Aug 9, 2015
    50
    49
    Hampshire
    Not sure if you have solved your problem yet but I had a similar problem, I suspected the battery would not hold it's charge and took it back to the dealer. They checked the vehicle and found the fault was a drain from an incorrectly wired reversing camera. They rewired it and it has been fine since. My advice is to take it back to your dealer and have the system checked.
