enganering advice (1 Viewer)
Nov 18, 2011
11,857
42,490
Planet Earth
A van
Over 25 year's
hi all
I need sum advice on threading a pipe cam connector nipple I have tried to show as many aspects off it the bit I want to thread is 1" OD blanked off with welded end I will have it drilled out to make a open pipe then try and get a thread on it stainless looking to put ball valve on to it
these were expensive when I got them and have only one so this must be a one shot solution
bill
43,207
48,815
One shot Bill......entrust it to an engineering workshop.
If it is stainless it will need a specific type of die.
Unless agreed otherwise, they f*** it up they source a new one.
Dec 6, 2011
11,470
25,061
South Wales
Coach built Adria
i agree with pappa john that needs to be set up in a lathe to ensure the thread is central and true so off to a local machine shop
Sep 23, 2007
1,702
1,966
Leicestershire
4 and many as a tugger
What you have there is a tri clamp. Do you need to replicate the same again. Try deltastainless.co.uk and nero.co.uk.
The threaded part looks like 1"BSP it will be an off the shelf part.
Comercial fuel solutions do some threaded pipe parts.
Wildbill
Nov 18, 2011
11,857
42,490
Planet Earth
A van
Over 25 year's
What you have there is a tri clamp. Do you need to replicate the same again. Try delta stainless.co.uk and nero.co.uk.
the threaded part I need it's the blank I need engineered or get another on but having problems as the company I got it from went bust
Sep 23, 2007
1,702
1,966
Leicestershire
Hi Bill they are all of the shelf tri clamp fittings. The one with the end blanked is a hose tail. It then has had the end welded closed. You could also try dixon europe in Preston. Give them a call you will find them very helpful. What thread do you need.
Wildbill
Nov 18, 2011
11,857
42,490
Planet Earth
A van
Over 25 year's
it's just to put a 1" or 3/4 valve on for the boiler to drain to the collar on the brewery I am building to ingress capacity I have the 50l plant but setting up 150l plant .
it's getting busy with orders
bill
Dec 27, 2014
967
3,361
Should be able to run it off in the lathe.
Do you have a pitch gauge?
Is it BSP? Unlikely to be metric.
If we had the threaded bit it wouldn't be difficult to establish dia/pitch.
Any local machine shop worth its salt should be able to do this.
Dec 10, 2013
3,419
11,954
South Staffs
Pilote P740GJ
Since 2013
Bill I agree with pj, that's an engineering workshop job but cost wise I should go down andymans route first, it may be cheaper.
Dec 12, 2010
5,368
21,198
Cumbria
since 2011
Looks like you could thread it 3/4" BSP, then put a 1" to 3/4" BSP reducing bush on it to replicate the threaded end you already have. If you have no luck with Andymans suggestions, I could spin it up on the Myford if you are stuck ?
Wildbill
Nov 18, 2011
11,857
42,490
Planet Earth
A van
Over 25 year's
calling them in morning thanks for reply's
bill
Wildbill
Nov 18, 2011
11,857
42,490
Planet Earth
A van
Over 25 year's
Looks like you could thread it 3/4" BSP, then put a 1" to 3/4" BSP reducing bush on it to replicate the threaded end you already have. If you have no luck with Andymans suggestions, I could spin it up on the My ford if you are stuck ?
only need a thread that will fit a ball valve ether 1" 0r 3/4 but will call those two company's first
thanks for reply off to bead now 50 bottles of beer in the boxes completely knackered and up at 6am
night all
