Endless Breeze? (1 Viewer)
Jul 26, 2015
229
634
Merseyside
Hoping to buy 2016
None whatsoever
Can I use one of these to run my Endless Breeze Fan when on EHU?
Click / hover to enlarge
Item Ref Code: SB16In Stock
240v Mains To 12V 2A DC Cigarette Lighter Voltage Converter Power Adapter SB16
( 27 customer reviews, see below )
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
Why not install a cigar lighter socket near where you will use the fan? You can use it all the time then, even on the move if you have a dog to cool as we do. :)
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
nice and cool, but where is his water bowl?
He doesn't have water when on the move, it tends to spill out on the bends! Been there, done that when we've forgotten to empty the bowl after a stop. But he is offered water every time we stop. He then goes to sleep within seconds of the vehicle starting.
I believe you can gerbil type feeders for cages but he seems happy with the current regime.
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
We used one of these, kept out in the Moho all the time. Great bit of kit.
Nov 30, 2009
6,545
148,888
Pickering
PVC the PUG
@Mousy we se one of those. They are great. But may be a bit big for use in that cage.
Mousy
3,485
20,319
Sa15 2DG
Since 2013
Sure, what ever you are doing is right for you and working, didn't want you to think I was suggesting otherwise. We saw these bowls mentioned on fun and found it so useful for our Ruby (who we sadly lost last September). I just thought I would pass the tip on as we used one at home too, saved the kids always kicking the water bowl over.
I know from your lovely holiday blogs how much Charlie means to you and the top quality love and care you provide him. (y)
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
I wasn't criticising! I hadn't seen those bowls before but will have a look when we get back and probably buy one. Many thanks for the link!
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I'm puzzles why you would want to. All MHs have a battery charger that tops up the battery so you just plug into the normal leisure battery sockets.
Dizzy Izzy
Jul 26, 2015
229
634
Merseyside
Hoping to buy 2016
None whatsoever
Our MH only has one 12v socket which is in the cab,so assumed using that would drain the van battery??
It does however have 240v sockets perfectly positioned for the endless breeze so thought it would be simpler in the short term to use an adaptor until we have extra 12vs fitted.
DBK
18,009
48,005
Plympton, Devon
PVC, Murvi Morocco
Yes, you are right. You can certainly use a 240V adapter. Just be wary of the current rating but we've never had ours on speed 3 so I suspect a smaller one would work but a properly rated one would be preferable.
Dizzy Izzy
Jul 26, 2015
229
634
Merseyside
Hoping to buy 2016
None whatsoever
Think I will go for one rated at 10A which I have seen on Amazon.
Thanks everyone.
Reactions: DBK
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That is unusual. But considering just how useful, for charging things, a 12V socket is and the parts cost little, it's worth think about fitting one or two.
TheBig1
17,601
43,041
not all 12v sockets look like cigar sockets. some are 2 flat pins. often found near the aerial socket for tv
