Emptying waste water (Fiat Rapido)
Discussion in 'Motorhome Chat' started by chirpy, Feb 21, 2015.
  1. chirpy
    chirpy Read Only Funster
    Feb 21, 2015
    5
    London
    I wonder if anyone can help.
    I have tried emptying the waste water which is clearly full but nothing is coming out. The light is flashing on the control panel too.
    Any suggestions?
    Thank you in advance
  2. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,917
    1,649
    Bungay Suffolk
    Try turning the waste pipe tap back and forth as there may be something stuck at the tap exit.. Or if that fails, try and pull the compete tap and pipe off.. First acertain that they are push fit pipes !! Keep yourself out of the way, the waste may well smell "awful"
  3. trekkin
    trekkin Read Only Funster
    Sep 12, 2014
    333
    495
    Staffordshire
    Are you sure that the tanks are full and that it is not just the sensors giving a false reading?
    Adrian
  4. musson
    musson Funster
    Dec 25, 2013
    397
    139
    grantham
    Hi have you tried pushing a screwdriver or something like that into the tap,try the tap handle in different positions,if this does not work try taking the tap off the pipe (make sure you wear old clothes it will stink)
    Also have a look under van and see if there is a plug in bottom of tank.
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,931
    notloB
    Could be a wodge of hard fat stuck. As has been said hands and knees job to have a look underneath MoHo to check out the pipe work from the tank to the tap. Mine was slow because someone had cabletied it up out of the way and made the water run uphill!
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,214
    7,334
    Nr Watton in Norfolk
    Firstly a big WELCOME to the Fun.
    Now, are you sure the tank is full as motorhome warning lights are notorious for inaccuracy and showing incorrect tank contents ... this goes for both waste (grey) and fresh water tanks.
    If you are sure and J&M's solution above doesn't work the you could try dislodging any blockage by pushing a flexible wire (net curtain Wire) up through the drain valve.
    EDIT while I was typing these ideas have been raised by others.
  7. chirpy
    Feb 21, 2015
    5
    London
    Thanks for your replies. I will try the screw driver and plug idea. Thank you :) That might be a job for tomorrow.
    Also, yes, I had just read about the sensor and it might be that too. Thank you for sharing that idea too :)
    What is strange is that we can't get any water out of the tank at all. We know there is waste water in it as we have used 50-60% of the fresh water we had.
    Any ideas on hoe to get it to release the waste water it is holding?
  8. chirpy
    Feb 21, 2015
    5
    London
    Thanks again! The flexible wire sounds like a plan too. Cheers :)
  9. laneside
    laneside Funster
    Aug 14, 2009
    3,542
    5,499
    Oradour sur Vayres
    Very seldom that our Rapido does that but if you are near to a tap stick the hose up the outlet. Last time we had a problem it was a broad bean stuck in the tap. Failing that there is a removable plate covering a big screw cap under the van but do not do it in your best bib and tucker
  10. B-well
    B-well Funster
    Apr 19, 2008
    1,168
    921
    Kent coast
    Because of the recent debate on emptying waste water into roads, public drains and like i believe the Rapido van has installed a valve blocker which only works if you are in a field and after dark. unlike Hymers they are active all the time.:reel::reel:
    Failing this try the old stick plastic tubing up and suck hard but as others have stated stand well clear when the gushing (emptying) starts to flow.
    • Like Like x 1
  11. makems
    makems Funster Life Member
    Sep 23, 2011
    2,647
    10,817
    Ingleby Barwick,,Teesside
    Is your van single floor or double floor? Alde or hot air heating?
    If single floor/hot air the waste tank has a plastic outer tank surrounding so that hot air from heating system can circulate around and stop it from freezing.
    There is a panel held by a couple of screws in the underside.
    Remove this and you should see a big plastic drain plug about 4" diameter on the underside of the inner tank.
    Unscrew this and depart rapidly else you will get drenched in smelly grey waste.
    The waste pipe coming out of the tank is push fit and can be pulled out to check if there are any blockages upside of the valve.
    if double floor or Alde I can't help I'm afraid.
  12. hilldweller
    Dec 5, 2008
    26,903
    25,756
    Macclesfield
    Fire a hosepipe back up the outlet, that might loosen things up.
  13. chirpy
    Feb 21, 2015
    5
    London
    You have all offered us fantastic advice! We'll try this tomorrow. Thanks a million! :)
    • Like Like x 1
  14. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,322
    YO11 2BD
    Are you sure the tap wasnt already open and the 50% - 60% has simply run out onto the pitch.
    • Like Like x 1
  15. chirpy
    Feb 21, 2015
    5
    London
    That's a possibility pappajohn. My other half said he thought it was already opened before I touched it but we're not 100% sure. A big day of cycling in snow and rain befuddles the mind ....
  16. Clive
    Clive Funster Life Member
    Apr 30, 2012
    751
    1,149
    Canvey Island
    On my Rapido it flashes as full when completely full or completely empty :D
  17. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,871
    11,440
    under a wand'rin' star
    Maybe run a bit of water through & turn the tap in all directions, before all the under-the-van activities then, just to check? :)
  18. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,518
    12,666
    Bolsover, Derbyshire
    Having a couple of years experience on here I still cant tell when some of you are joking
    Please tell me you don't do this yourselves, or if you do you wait till you are at home on your own hose, or at least use the waste water area hose
    You will have people using the fresh water supply hoses o_O
  19. iandsm
    iandsm Funster
    Jan 3, 2008
    1,574
    2,738
    Suffolk
    So does mine so I disconnected the sensor wire from the 12 volt distribution box. We know when its nearly full as the water goes down the kitchen sink slowly. Problem solved
    • Like Like x 1
  20. busby
    busby Funster
    Aug 18, 2011
    3,394
    3,203
    derbys
    If i run out of fresh water my waste is full...BUSBY.
