I have a £5 collapsible plastic water container from Go Outdoors which fits nicely under my drain tap, and means I can carry it easily to the grey water disposal. Squashes flat for storage...
Not too sure where you get your information from but a lot of this is wrong wrong wrong, most roadside drains go straight to a surface water system, usually the local water course albeit via culverts, they do not go to foul sewers which go the sewage treatment plants
All house built in the last 10 years or more are not allowed to discharge top water, gutters roof drive etc to sewer, it must go to the surface system
Please please please do not follow this advice it is wrong, roadside drains are for [HI]clean surface water only[/HI], same applies to downpipes on most modern houses, roof water only
Clean????
In what way is it any cleaner than grey waste?
:Cool:
Wow how to become public enemy number in a few words. Here are a few facts that people should understand. In a residential area all road drains go into the sewers, can’t see a problem with dumping grey water down them, might help flush out all that fat. Roads run by the highways agency have to go through a SUDS process to remove carbon pollutants, well apart from a few foods bits[HI] I don’t think my grey water is quite that bad.[/HI] Old country roads tend to use soakaways, definitely not a place to use. I would always use a site where available; I use a pipe where there isn’t a drive over. There are times however when you have [HI] no choice so the use of a suitable road drain is fine,[/HI] with the use of common sense and that includes closing the tap so as not to leave a snail trail.
once you get out of the site just crake the valve and leve a slippery trale of water no problem
Then some innocent motor cyclist goes arse over tit on contaminated water on the highway
I think Bill was being ironic..........:thumb:
Old country roads tend to use soakaways, definitely not a place to use. I would always use a site where available; I use a pipe where there isn’t a drive over. There are times however when you have no choice so the use of a suitable road drain is fine, with the use of common sense and that includes closing the tap so as not to leave a snail trail.
I always fall for Bills humorous posts oh:
