Emptying fresh water tank
Discussion in 'Introduce Yourself' started by Lisa, Oct 12, 2014.
  1. Lisa
    Lisa
    Aug 5, 2014
    20
    11
    Just enjoyed our 2nd weekend away in our Knaus Sun ti. As newbies we are still on a learning curve. All going well but we cannot work out how to empty fresh water tank. Can anyone advise? Thank you all in advance. Lisa and Dave
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    Different vans have different methods.
    On our Autoquest there was a flexible pipe with a tap in the end, similar to the one for draining the grey tank, and accessed from outside the van where it was clipped underneath.
    In the Burstner there is a plug in the bottom of the tank, similar to a small sink plug. It is attached by a chain (normal plug chain) to the underside of the large access cap. To drain the tank I unscrew the cap and pull on the chain then leave the plug hanging until it is done before replacing it.
    When you do work it out don't forget to drain the hot water tank (you may need to open both manual and automatic drain valves).
    • Like Like x 1
  3. Lisa
    Lisa
    Aug 5, 2014
    20
    11
    Thanks for that. All we can see when we open the cap inside on top of tank is an overflow tube which is vertical in the tank. You can look down through tube to outside. Not sure whether we should be unscrewing this tube?
  4. GJH
    Aug 20, 2007
    27,346
    34,941
    Not come across one of those I'm afraid. Hopefully a Knaus owner will find this thread before too long.
  5. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,850
    11,041
    Glasgow
    Sorry, cant help you but Hello and welcome :)
  6. davejen
    davejen Funster
    Aug 21, 2008
    1,260
    717
    Kirkpatrick Fleming Dumfries
    We usually run the taps with fresh water to fill the grey tank then drain that, this way it clears any bits of grey water left from before,and runs clean water through so no smelly water left, if you see what I mean........
    Cheers, Dave(y)
  7. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Hi and welcome-our LMC is quite basic,a plug in bottom of tank which I have to reach in and pull out.
    Can you see anything in bottom of tank ?
  8. Lisa
    Lisa
    Aug 5, 2014
    20
    11
    The only thing we can see in the bottom of tank is the overflow pipe which stands vertically. If we fill with too much water it flows into the top of pipe and runs down and out of tank. You can see the hole in bottom of this tube if you look into it. Other than that we cannot see any plugs. Thought we might be being thick but perhaps not?
  9. Al-Di
    Al-Di Funster
    Mar 15, 2014
    990
    3,826
    prestwich
    Welcome,
    Alan + Diane,
  10. Shazrick
    Shazrick Funster
    Oct 16, 2013
    875
    234
    Lincolnshire
  11. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    Just spoken to a friend who has a Knaus and he says he has to unscrew that tube.
    It is plastic on his,so be carefull not to cross the thread when re-fitting .
    • Like Like x 2
  12. Lisa
    Lisa
    Aug 5, 2014
    20
    11
    Thank you for your help Mike and Carolyn. We thought about that but didn't like to do it in case we broke it.
    Thanks to everyone else as well. Really pleased we found Motorhome fun!
    • Like Like x 2
  13. PenelopePitstop
    PenelopePitstop Funster Life Member
    Sep 3, 2007
    2,480
    1,342
    Royston Vasey and beyond!
    We had a Knaus Sunliner for 5 years and the only way we could drain our fresh water tank was by turning the taps on and thereby draining it all through the grey waste tank.
  14. Roryboys Dad
    Roryboys Dad Read Only Funster
    Mar 19, 2012
    631
    804
    Glapwell Derbyshire
    You've probably done it by now but we had a Knaus Sport and the water tank was emptied by unscrewing the pipe that sticks up from inside the base of the tank.
    Make sure when you put it back that it seals tightly, firmly but not excessively, or you'll get water leaking out – a bit of PTFE tape around the thread will solve that.
    Hope this helps.
    :france::france::france:
  15. Lisa
    Lisa
    Aug 5, 2014
    20
    11
    Thanks for your help. Will try undoing the pipe. ( very carefully as it looks as though it could easily break.
  16. Mick H
    Mick H Read Only Funster
    Oct 13, 2007
    40
    Near Leicester
    As the owner of a 2005 Knaus Sun Ti, I can confirm that unscrewing the pipe, is the correct method, as already described.
    It's more robust than it looks, and is quite easy to remove, but not always as easy to refit. Take your time.
    I modified ours, making it easier to remove and refit.
  17. cruiser
    cruiser Funster Life Member
    Sep 12, 2012
    2,987
    2,852
    northampton
    hello and welcome t the house of fun
  18. Lisa
    Lisa
    Aug 5, 2014
    20
    11
    Thank you Mick
  19. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Valencia City, Spain
    Hi Lisa & Dave and welcome to the Fun! (y):welc:
    See what a great forum this is? :laughing:
    • Like Like x 1
