I was told by SVTech that they could not update my train weight. The van (as avatar) was originally 5 tonnes MTPLM and has been uprated (by SVTech) to 5.5 tonnes. The gross train weight is 6 tonnes, leaving only 500 kg for a trailer.
A ton as in pay load or towing capacity?
My trailer is an Ifor Williams CT115 which has a GW of 1400kg and an UL Wt of 350kg. The Up is bout 930kg depending upon precise spec - ours is a Move Up so pretty basic but with air con. We are well inside our gross train weight of 6T. Hope this helps.@Sloany198 thanks do you know the weight of the two combined?
Wow, our last trip across the weighbridge came in at 4320kg for the van and the two of us so we have plenty to spare. We don't carry a vast amount with us and usually buy our supplies locally. Unfortunately we are not able to get away for more than a couple of weeks at a time so that may help.You must be more organised than me on what you carry about with you. Have put mine on a weighbridge a couple of times and always seem to be near the 5 ton mark leaving me only a ton to play with. Must have a sort out before I get a tow car.
